bigxie
Sorry everyone, Apex may get delayed a little, I have to get this hit and run sorted out. If all goes well, I'll have this guy tomorrow.
Man, that sucks! Sorry to hear about someone hitting your new car!![]()
It's Andrew Xie (bigxie) on Twitter
So, I'm going to be starting on the Blur restoring menu of the Toolbox in a bit. What are some common apps people like to restore from the removedapps archive?
Sorry I'm a total noob here, but how do I go about restoring some of these apps? Like the blur gallery for example..
No, that sounds right. All that the widget add-on does is is sort widgets from the same program. So if you have Beautiful Widgets, instead of having all of the different types of widgets listed out on the select screen it puts them into one folder which you can then select from on the widget menu. It makes for a much more clean and easier to navigate menu all in all.
mine is up to date 1.2.2 adw ex
standard adw may be 1.3.3
Thread #776
http://androidforums.com/droid-x-al...nning-fast-can-12-16-10-a-16.html#post2014538
open thermial emulator and tyoe su then enter
this will give you permission. type gallery -mot
make sure there is a space after gallery
Can i deodexed my droid x running this rom (apex 1.3.1)? I want to use the puzzle lock dx file and the only way it will work is if im deodexed. But im scared with a custom rom i will mess something up.
bigxie
download metmorph from the market and go here ,,,they have a ton of them and its simple,,,they have instructionsAny way to make changing the battery icons in the notification bar easier?
Also can you add Google Voice icon into dialer?
I tried Metamorph and droidpirate. I installed the glow battery circle.zip and than later decided I wanted one from droid pirate using Metamorph. Now I have both kinds of icons switching back and forth.download metmorph from the market and go here ,,,they have a ton of them and its simple,,,they have instructions
droidpirate.com
I use an app called Shootme. it then stores a screen shot in a folder called shootme. Drag it to the PC and upload to photobucket and post it
That is exactly what is happening! So.....how do I fix it?Most likley because the metamorph thing you did from Droid pirate only had the icons in 20% increments and apex reports in 10% so the Droid pirate thing only replaced the 0 20 40 60 80 and 100% icons (plus charging icons)
