Did you try the stock version ROM which installs from a pc with commands ? Maybe that will work for you . This will install root , recovery and the ROM all in one shot . If not I suggest flashing back to stock VM and starting all over again . Good luck .
Near 200 downloadsnext release will have some cool effects
Hmm... What were the errors u got?? I test flash with newest twrp and it worked fine... U use stock install kit or just rom??after a week of trying to in stall this ROM on my wife's phone finally got it by flashing an older recoverie older then phenomx4s twrp it work great then flashed back to the latest recoveri and is all good now
Help, please! I'm no stranger to flashing ROMs and I'm really trying to flash this ROM. But for some reason, I can't boot into recovery all of a sudden. I recently flashed the latest TWRP, but never booted into recovery since. I've never experienced anything like this before. Ideas?!
Thanks for the great evaluationWell after a long testing session I've come to know this ROM inside out . There are 3 issues I've encountered that I know of so far . Upon installation there are 3 force closes that happen on initial setup . One is hangouts , second is UI and third is Google play services . That's problem number one but this does not affect the functionality of the ROM once you're in as far as I can tell . The second issue is the notification LED which for me doesn't work most of the time . Third and worst is a battery power consumption and ram consumption issue . I'm pretty sure that's an issue with Google chrome browser . It's known to have these issues and it's one of the differences between L and Moonshine . I'm not really complaining , Just trying to help point out any possible bugs . Meantime I will keep using Moonshine 2.9a because I consider it to be one of the best ROMs I've ever installed on any phone . I can also comment on sound quality . being an audiophile for over 35 years I immediately noticed that L sounds somewhat dull and muffled . Moonshine sounds louder and cleaner overall . Sometimes sound enhancing can be a bad thing . Besides why would you need Dolby decoding on a 2 channel audio phone device ? Like always and once again , thank you for the great effort on your part to make our phones and lives a little better .
acid is mainly noticed with headphone jack... The dolby is simulated hench the slight muffle [our little monotone speaker isnt too great to begin with lol] u are correct chrome uses too many resources and will b replaced with aosp browser with fixed chrome bookmark sync
the fc
The next installment will likely be the pinnacle of this ROM and its evolution from a stock bloated nightmare. You guys haven't seen nothing yet.![]()
A little taste of things to come![]()
U serious?? Lol its wifi settingsUmmm, what is it?
