MustardSeedPon
You know on a call you can bring up the number pad right?
Yes, but you cannot activate the phone when in phone mode. Only in the activation mode can you do this. In activation mode, there is no number pad.
Ok, is there anything important left to do now that I have cyanogen10, gapps, and I flashed the baseband to v8? It's been awhile for me to be on root or jailbreak...What about some kernels or good apps?
Also, huge thanks to you guys. Especially stcarlso![]()
Is there a reason why my internal sd is not being recognized by my comp now? My external one is reading fine...
Ok after flashing this I'm stuck on the CM10 boot screen. About how long does it take to boot after a first install? Do I just do a battery pull and then do a wipe in CWM? Just wondering as it's been cycling for about 20 minutes now.....
LickeyMong, do you have these? or one of these?
Two problems I still have-
-one in about every 3 boots, it just stays on the CM10 logo and never boots, requiring a battery pull.
-phone freezes in my pocket (SoD?) and requires a battery pull. Freezes with the screen off, no games running.
Well two issues,
1. For the past 3 days my battery has been getting extremely hot, mostly when I turn my 3G on.
2. Since I had that battery issue, I reflashed my device, it all went well, booted for the first time and it had 4G, then as soon as I turned data off and then back on it stays at 3G. So the bigger issue is my battery, why is it getting so hot? Is this dangerous? Can it damage my phone?
Edit: 4G working fine now, just needed to tweak some settings.
Curious... any news on 4.2 JB? I'd love to get this app: https://play.google.com/store/apps/details?id=net.nurik.roman.dashclock&hl=en
Also, people talk about a GPS issue. I don't have a GPS issue....
Another question too: any news on MTP?
Thanks,
Demortes
Verizon released a prepaid version of this phone. The only differences between the 2 that I can see are that the prepaid version does not have 4G connectivity and they changed the name of it to the LG Optimus Exceed. Just wondering if anyone knows if this ROM will work for it or not. Thanks in advance.
Thanks,
Demortes
