^ Because if both are on, it only uses the wifi, and wifi use much less battery.
EDIT:
any idea on GPS? can't get it with GPS test or gps status. tried in two different spots so its not the satellites either.
(sorry for repost, but I hate having last post on a page)
did not fix was not malfunctioning bc I works now that its back to stock gb but im about to reup to cm10The 4G wont matter, the program is only interested in the GPS satellites. You really should be outside when downloading the xtra data, its far more accurate that way. If you go outside and it still doesnt work, then the GPS on your phone is either malfunctioning or the GPS driver is not packaged with this ROM.
I'd love to see JellyBean 4.2 (Maybe 4.3 one day) for the Lucid!
Also my battery only gets hot when I'm using JUST data. If I have my WiFi connected and data on it doesn't heat up. Strange.
Sorry for the double post but since this thread only has a few active members and I wanted others advice I made a thread as well (I'm also not sure if this is a cm10 problem):
I'm on Verizon as well as CM10.
Texts that are longer then 160 characters always used to send to other verizon members.
I realized that recently they haven't been sending. I really don't want to break them up as I never have. I will go back to stock if I have to, but I don't want to.
Ideas on why they won't send anymore?
CM 10.1 (version 4.2.1 of Android) breaks Bluetooth, and I'll have to redo my display drivers job. When they fix that I'll take a look.
I don't experience this issue. A few weeks ago I sent a text that was accidentally too long and it appeared to break up just fine. Could you back up texts, clear data and cache for mms.apk, and restore them?
See, I don't want to break them up though. Today I received a text that was probably at least 200 characters as one text (always has worked for verizon to verizon like that for me) but now if I try to send a text just like that, it just doesn't send.
I can try clearing that, but how exactly do I do that? Also it isn't really an mms, is that the right one?
EDIT: I reset settings in Go SMS as well as cleared data for it and stock messaging app and still doesn't work.
Handcent SMS also doesn't help.
stcarlso,
looking at your github, how exactly do we tell what you changed from stock CM10?
EDIT: Aka I'd be interested in knowing what changes to make if I were to try to do this myself. But that appears to be quite a few, so perhaps not worth bothering right now.
Did you flash the baseband?
Shoot my phone just jumped into a bootloop, I cleared both caches and cant get out. ideas?
occaisionally it will stay on for like 15 seconds but...
