[ROM][BETA] CyanogenMod 10 for the LG Lucid
You can just use your ps3 controller by using sixaxis. So much easier
It doesn't work on my rooted ICS with an otg cable or six axis I've tried everything. Can someone confirm that cm10 has the correct drivers to use an otg cable or Bluetooth through the six axis app
CM10 can't do anything about it - the lucid USB PHY has no 5v supply so it cannot provide power to USB devices. It might work over Bluetooth. Since I haven't tried it I don't know about drivers.
So i installed cm10 using the instructions here [Guide][How To] Install CM10 on LG Lucid - Pastebin.com
when i was done i wiped data/factory reset and cleared cache and rebooted. now ive been stuck at the lg screen for about 10 minutes.
Is this normal? Should I be worried? What should I do?
*face palm* haha no. Your problem is you don't factory reset or wipe data after you flash a rom. You do all that before. Nothing after. Now you need to boot into recovery. Re wipe everything g and reflash the rom. Do you know how to boot into recovery?
yea pull battery vol down and power while plugged into usb.
so then i would factory reset wipe cache then reinstall cm10 gapp and baseband? then just reboot?
when im in recovery it says wipe data/factory reset. when i click that does it do both? or is there some other way to do factory reset from recovery
for my baseband can i use this? i got it from this thead [Guide][How To] Install CM10 on LG Lucid - Pastebin.com
is there another one i can use?
now when i try to boot into recovery it gives me a picture of an android guy and a open box with an arrow coming out of it. anyone know what this is?
So here's what you do...
COMPUTER:
Download b2 cm10
Download vz8 baseband
Download gapps
Transfer all files to external SD card on the root directory.
PHONE:
Download and install from market:
ROM manager
Open ROM manager
Install the latest cwm recovery
BOOT INTO RECOVERY by pressing and holding volume up and power and just continue through the factory reset by pushing power a few times. In cwm recovery. Backup. Wipe data/ factory reset. Wipe cache. Advanced- wipe dalvik cache. Flash cm10. Flash gapps. Flash baseband. Reboot.
Welcome to CM10!!
i wanna re install cm10 but i ve this problem...LGE CDMA DRIVER or LG Electronic inc....
does anyone install this firmware http://csmgdl.lgmobile.com/swdata/WDLSW/LGVS840PP/AVRZTN/VS840PP2_02/VS840PP2_02.S2_02.P58017.R5.cab and succed connect modem or ethernet mode....
i've got problem,,
[/URL][/IMG]
i tried these driver and no one work...(install one > restart > didnt work > uninstall > restart > install another one > didnt work > > > > and searcing solution for 18 hours...... no one succeed...
[/URL][/IMG]
help me pleeeeasee....:<
COMPUTER:
Download b2 cm10
Download gapps
PHONE:
ROM manager
Open ROM manager
Welcome to CM10!!
I've done this atleast 6 times and can't get past the LG screen. I'm unsure of what else I can try. Any help would be appreciated
