takethebox
Tickerguy and Isaac you guys are fantastic. Started running the most recent build on my MT and it is running fantasticly. Thanks for the hard work and can't wait for the next build
I've realized I haven't seen the little CM7 little icon in the top left the last few days. Is that normal?
)Yeah, it's just a background service from the CM-team that sends statistical data about the phone.
Relevant: http://stats.cyanogenmod.com/ (Look how many individual installs of CM7 there are for the Ascend.)
Ok cool. Thanks for the heads up on that info.
So with your build Isaac, does it pretty much work like tickerguys but just tweaked a little bit? What's different?
Check my previous post above.EDIT: Admittedly, I've been sitting here running quadrant over and over trying to break the 4000 mark. I finally did. 4022.Check my previous post above.
Isaac, since I am very interested in trying your build out, I went to your other thread but could not find a link to the new build. Could you help me out?
It's not up, yet. I had to rebuild. I'll bump up the other thread when it's up.
cool... isaac, can you tell me how to make a rotary lockscreen? i dont know what to add, edit, or modify to get the lockscreen from tabs to a rotary dial...
I honestly don't know. I'd imagine it would take changing some *.9.pngs in framework-res.
i usually just take someones rom who has alot of cool stuff in it, add a kick ass theme, and give them most of the credit.... i think i will stick with that!
So would I be able to just install yours over tickerguys version or should I do a factory reset and install it?
OK thanks man your work is amazing!!It's not up, yet. I had to rebuild. I'll bump up the other thread when it's up.
You should be able to flash right over.
isaac and tickerguy, if i win the lottery you guys are getting a big chunk of itYou guys (Isaacj & TickerGuy) ever considered making your own custom rom?
dude that is what they are doing they are not the same jsut made from the same source with different flavors of features and designs![]()
we mean other than cm7... and froyo
Well, every Android ROM can trace its roots back to AOSP. CM7 is just a modified version of 2.3 AOSP. However, the CM team (IMO) have been careful to keep their source as "vanilla" as possible. They went through the painstaking trouble to make CM source compilable for MANY devices. I've always been (and continue to be) so impressed with what they've done. Just imagine if you took just AOSP 2.3 and tried to build it for the Triumph. That would be rough.
One other Linux-based OS I'd like to see on the Triumph is MeeGo. Since the Triumph is an ARMv7, it should be able to run MeeGo. Unfortunately, the MeeGo handset platform doesn't see very much attention. Here's an old demo of MeeGo running: MeeGo 1.1 on Intel Moorestown Phone - YouTube
Speaking of other OS's I wanted to speak with you about something but since I cannot pm you and would like to avoid cluttering these threads what would be the best method of contacting you?
