Triumphfeen
R u sure u r on the 9/18 update did u atleast wide the cache patron?
I wiped EVERYTHING except my /data... I dont wanna play angry birds for the umpteenth time. ;-) and yeahR u sure u r on the 9/18 update did u atleast wide the cache patron?
When can we expect a front cam fix?
Just reporting, not complaining, but I am experiencing constant rebooting. Can't figure out the cause, Wifi does not seem to be the problem. Any ideas?
--->I think I solved my rebooting problem by going through the whole wipe data/factory reset, format /system process.
In my experience, most problems that no one else seems to have come from leftovers that didn't get cleared.
Also, maybe I'm just stating the obvious, but to everyone that drops a one and out post about "X doesn't work", or, "I have to have this be able to use this ROM, please hurry"...
2. 95% of the bugs folks are reporting have ALREADY been addressed either in thread up till now or in the very FIRST post. Read the thread, please. Read the whole thing... read it twice. Otherwise, you are just wasting space.
My sensor is not workin right, whenever Im on the phone talking the screen turns off and on over and over again.
READ THE FIRST FEW POSTS AND FOLLOW THE INSTRUCTIONS!!!
That is in the instructions. I am not trying to be mean or pick on you, but it is in there.If you have odd problems and didn't do a factory reset from Clockwork, try that before reporting bugs.
Did you try and overclock? My Triumph freezes and reboots if I clock it past 1500mHz
I've been following this thread from the beginning but I haven't read through it all recently. Where can I find the latest builds? Is there any reason why they're not being hosted through github, that seems most logical place to store them, instead of all these mediafire links. I like to know that where I'm getting something is legit.
Aww poor baby, you don't trust the links they put up? then don't use them.
Damn bro, what crawled up your ass? It was just a suggestion, if you read my post you'd see I already flashed what I'd found. In fact at this point I've tried several. If there's a reason for using these shitty file sites, like them being an affordable means of distribution or something then tell me, otherwise I thought it might be more useful to store builds with the source they're built from, who knows, maybe even provide a hash so people can verify the files they're loading to make sure they're not corrupted. It saves everyone time by cutting down on time wasted chasing weird errors. Anyways, I'm going to keep trying stuff I've dredged out of Google. Got some tips from people at work too.
Trying Hotfile.com: One click file hosting: update-cm-7.1.0-RC1.1-Triumph-KANG-signed.zip
Thanks! In any case, now that I know it's an outstanding issue, I will happily await its resolution. Guess no wifi for me for a while.
actually the current build has working wifi it just been made to go to sleep automaticly when you put your phone to sleep. and turn back on when you use you phone. it saves on battery power too. and it will not lockup so easily.![]()
