I was updating to the 9/20 build (factory reset) and after selecting reboot my phone is dead. when powering on it constantly vibrates until the battery is pulled. when connected to a computer it detects a drive (100mb MOBILE Ewith nothing in it. any ideas!?? or am i screwed?
use k9 mail.... it works awesome on this build!First time poster...Thank you everyone for your hard work! I have been following this thread for a while and finally decided to load up the build...so far no major issues except the ones mentioned. I do have a minor issue with stock email. It crashes when trying to reply to the emails...anyone have that problem and solution? TIA
BTW, besides doing this project here, ticker guy (Karl) is an awesome stock trader and finance person at tickerforum (I hope ticker guy do not mind the prop)![]()
watching a live stream as i write this. no force closes so far.Interested in migrating to this from stock, but can someone test one app for me on it? Grab the latest ustream client with this installed and try to view a stream?
Something weird on my Nexus One - on stable/release versions of CM (or stock), this app is rock solid. On nightly/experimental versions - crash the moment you tried to view any stream.
So if this works, since I do a bit of ustream work...
Thanks in advance!
You mean, for instance, the link to the one I use that's in the posts that I am maintaining?Ticker, I would really suggest putting a link to a good cwm in the first post.![]()
open up apps, "theme chooser",,,,there's 3 to pick fromHow do you get the signal bars n 3g to b green or blue mine r still grey
Would people please read the top posts in the thread before asking for something that is already there?
You mean the link in the second post that almost seems like an afterthought and is well after the steps for actually flashing the ROM?
Well i switched to the punkrom for now, on cm7 my 3g would stop working alot and i had to go to airplane mode and back to fix it, also my wifi, if i would lock my phone when wifi is connected after i would unlock it it would not work, it said i was connected to my router but my internet wouldn't work, had to turn off/on wifi to fix it. For now I'll wait til this is fully working to give it another try
Reading......a dying skill![]()
Does anyone know of a decent way to reprogram a button to force a reboot?
The only reason I'm asking is because I have a habit of leaving Wifi on. I'm not sure if that's the cause or maybe some setting I've derped around with wrong. Whenever the phone went to sleep, I was unable to get the screen to fire back up. The backlight comes back on, and I think that it's responsive to touch(not locked up), just no picture.
If I can repurpose a key to reboot, it would fix things.
(My case is hard to pop off and on, so I'd rather just waste a key on it)
BTW, everything else is great. Ticker, you and Isaac rock!
Oh my god, all I did was point out that the link to an appropriate CWM is listed WAY after the steps to flash the ROM. I know of four people now including myself that bricked their phones (thankfully not permanently) partly because we were using an older CWM recovery that can cause the /FAT partition to get formatted if you aren't careful. I never blamed Tickerguy and in fact praised the ROM and the work he is doing earlier on - and I still am very thankful and excited for the work that is being put into it. I made a simple observation, got a sarcastic reply, and replied in turn.
Oh the joy of forums. For every great person there are a hundred ready to troll and flame away ... *le sigh*
TG, I am sincerely sorry if my suggestion offended you. It wasn't intended to do so.
I/Database( 334): sqlite returned: error code = 8, msg = statement aborts at 1:
[PRAGMA journal_mode = WAL;]
E/Database( 334): sqlite3_exec - Failed to set WAL mode for [/data/data/com.and
roid.providers.telephony/databases/telephony.db]
I/Database( 334): sqlite returned: error code = 8, msg = statement aborts at 37
: [CREATE TABLE IF NOT EXISTS android_metadata (locale TEXT)] attempt to write a
readonly database
E/Database( 334): CREATE TABLE android_metadata failed
E/Database( 334): Failed to setLocale() when constructing, closing the database
E/Database( 334): android.database.sqlite.SQLiteException: attempt to write a r
eadonly database
E/Database( 334): at android.database.sqlite.SQLiteDatabase.native_setLoca
le(Native Method)
E/Database( 334): at android.database.sqlite.SQLiteDatabase.setLocale(SQLi
teDatabase.java:1987)
E/Database( 334): at android.database.sqlite.SQLiteDatabase.<init>(SQLiteD
atabase.java:1855)
E/Database( 334): at android.database.sqlite.SQLiteDatabase.openDatabase(S
QLiteDatabase.java:820)
E/Database( 334): at android.database.sqlite.SQLiteDatabase.openOrCreateDa
tabase(SQLiteDatabase.java:854)
tabase(SQLiteDatabase.java:847)
E/Database( 334): at android.app.ContextImpl.openOrCreateDatabase(ContextI
mpl.java:572)
E/Database( 334): at android.database.sqlite.SQLiteOpenHelper.getWritableD
atabase(SQLiteOpenHelper.java:118)
E/Database( 334): at android.database.sqlite.SQLiteOpenHelper.getReadableD
atabase(SQLiteOpenHelper.java:187)
E/Database( 334): at com.android.providers.telephony.TelephonyProvider.que
ry(TelephonyProvider.java:382)
E/Database( 334): at android.content.ContentProvider$Transport.bulkQuery(C
ontentProvider.java:174)
E/Database( 334): at android.content.ContentProviderNative.onTransact(Cont
entProviderNative.java:111)
E/Database( 334): at android.os.Binder.execTransact(Binder.java:320)
E/Database( 334): at dalvik.system.NativeStart.run(Native Method)
E/SQLiteOpenHelper( 334): Couldn't open telephony.db for writing (will try read
-only):
E/SQLiteOpenHelper( 334): android.database.sqlite.SQLiteException: attempt to w
rite a readonly database
E/SQLiteOpenHelper( 334): at android.database.sqlite.SQLiteDatabase.native
_setLocale(Native Method)
E/SQLiteOpenHelper( 334): at android.database.sqlite.SQLiteDatabase.setLoc
ale(SQLiteDatabase.java:1987)
E/SQLiteOpenHelper( 334): at android.database.sqlite.SQLiteDatabase.<init>
(SQLiteDatabase.java:1855)
E/SQLiteOpenHelper( 334): at android.database.sqlite.SQLiteDatabase.openDa
tabase(SQLiteDatabase.java:820)
E/SQLiteOpenHelper( 334): at android.database.sqlite.SQLiteDatabase.openOr
CreateDatabase(SQLiteDatabase.java:854)
CreateDatabase(SQLiteDatabase.java:847)
E/SQLiteOpenHelper( 334): at android.app.ContextImpl.openOrCreateDatabase(
ContextImpl.java:572)
E/SQLiteOpenHelper( 334): at android.database.sqlite.SQLiteOpenHelper.getW
ritableDatabase(SQLiteOpenHelper.java:118)
E/SQLiteOpenHelper( 334): at android.database.sqlite.SQLiteOpenHelper.getR
eadableDatabase(SQLiteOpenHelper.java:187)
E/SQLiteOpenHelper( 334): at com.android.providers.telephony.TelephonyProv
ider.query(TelephonyProvider.java:382)
E/SQLiteOpenHelper( 334): at android.content.ContentProvider$Transport.bul
kQuery(ContentProvider.java:174)
E/SQLiteOpenHelper( 334): at android.content.ContentProviderNative.onTrans
act(ContentProviderNative.java:111)
E/SQLiteOpenHelper( 334): at android.os.Binder.execTransact(Binder.java:32
0)
E/SQLiteOpenHelper( 334): at dalvik.system.NativeStart.run(Native Method)
I/Database( 334): sqlite returned: error code = 1, msg = no such table: android
_metadata
E/Database( 334): SELECT locale FROM android_metadata failed
E/Database( 334): android.database.sqlite.SQLiteException: no such table: andro
id_metadata
le(Native Method)
atabase.java:1855)
atabase(SQLiteOpenHelper.java:197)
I/PowerWidget(24561): Setting up button: toggleSound
E/DatabaseUtils( 334): Writing exception to parcel
E/DatabaseUtils( 334): android.database.sqlite.SQLiteException: no such table:
android_metadata
E/DatabaseUtils( 334): at android.database.sqlite.SQLiteDatabase.native
E/DatabaseUtils( 334): at android.database.sqlite.SQLiteDatabase.setLoc
E/DatabaseUtils( 334): at android.database.sqlite.SQLiteDatabase.<init>
E/DatabaseUtils( 334): at android.database.sqlite.SQLiteDatabase.openDa
E/DatabaseUtils( 334): at android.database.sqlite.SQLiteOpenHelper.getR
eadableDatabase(SQLiteOpenHelper.java:197)
E/DatabaseUtils( 334): at com.android.providers.telephony.TelephonyProv
E/DatabaseUtils( 334): at android.content.ContentProvider$Transport.bul
E/DatabaseUtils( 334): at android.content.ContentProviderNative.onTrans
E/DatabaseUtils( 334): at android.os.Binder.execTransact(Binder.java:32
0)
E/DatabaseUtils( 334): at dalvik.system.NativeStart.run(Native Method)
D/dalvikvm(18172): GC_EXTERNAL_ALLOC freed 96K, 52% free 2782K/5703K, external 9
39K/1033K, paused 213ms
E/SqliteWrapper(25701): Catch a SQLiteException when query:
E/SqliteWrapper(25701): android.database.sqlite.SQLiteException: no such table:
android_metadata
E/SqliteWrapper(25701): at android.database.DatabaseUtils.readExceptionF
romParcel(DatabaseUtils.java:158)
romParcel(DatabaseUtils.java:114)
E/SqliteWrapper(25701): at android.content.ContentProviderProxy.bulkQuer
yInternal(ContentProviderNative.java:330)
E/SqliteWrapper(25701): at android.content.ContentProviderProxy.query(Co
ntentProviderNative.java:366)
E/SqliteWrapper(25701): at android.content.ContentResolver.query(Content
Resolver.java:271)
E/SqliteWrapper(25701): at android.database.sqlite.SqliteWrapper.query(S
qliteWrapper.java:59)
E/SqliteWrapper(25701): at com.android.mms.transaction.TransactionSettin
gs.<init>(TransactionSettings.java:66)
E/SqliteWrapper(25701): at com.android.mms.transaction.TransactionServic
e$ServiceHandler.handleMessage(TransactionService.java:628)
E/SqliteWrapper(25701): at android.os.Handler.dispatchMessage(Handler.ja
va:99)
E/SqliteWrapper(25701): at android.os.Looper.loop(Looper.java:130)
E/SqliteWrapper(25701): at android.os.HandlerThread.run(HandlerThread.ja
va:60)
W/TransactionService(25701): Exception occurred while handling message: { what=1
when=-84ms arg1=1 obj=com.android.mms.transaction.TransactionBundle@2b062ae8 }
W/TransactionService(25701): android.database.sqlite.SQLiteException: no such ta
ble: android_metadata
W/TransactionService(25701): at android.database.DatabaseUtils.readExceptionF
W/TransactionService(25701): at android.content.ContentProviderProxy.bulkQuer
W/TransactionService(25701): at android.content.ContentProviderProxy.query(Co
W/TransactionService(25701): at android.content.ContentResolver.query(Content
Resolver.java:271)
W/TransactionService(25701): at android.database.sqlite.SqliteWrapper.query(S
W/TransactionService(25701): at com.android.mms.transaction.TransactionSettin
W/TransactionService(25701): at com.android.mms.transaction.TransactionServic
W/TransactionService(25701): at android.os.Handler.dispatchMessage(Handler.ja
va:99)
W/TransactionService(25701): at android.os.Looper.loop(Looper.java:130)
W/TransactionService(25701): at android.os.HandlerThread.run(HandlerThread.ja
va:60)
