dsmryder
Android Expert
Howcome oovoo doesnt work?
Skype works for me. I would try that to see if it's the type of program or if it's just ooVoo.
Sorry, I meant clear the caches. Trying to avoid reinstalling everything again if I can.
I have my phone overclocked to 1200mhz and all voltages 800mv.Are you overclocked/underclocked? Undervolted? if so, by how much?
Cpu profile savage and all clocks tested with every stability test i can find.
The phone would not turn on it had the red battery icon everytime I tried to start it.
They work together, but your CPU will max out the whole time and this will drain your battery fast.Any chance BT and WiFi can work at the same time? I want to use a bluetooth gps module... it sucks that wifi doesn't work with bt on
Nope, if you don't use it you can just uninstall it.Hey after updating today I keep getting this "Google talk authentication failed" message I tried formatting system, clearing cache, clearing dalvick cache, reflashing the rom, and reflashing gapps ... and after all that I still get the message.
Honestly the pop up is pretty annoying. Seeing as I don't actually use Google talk could I just get rid of it or would it have any consequences on any other aspect of the phone.
EDIT: Tried flashing Google Talk so I could stop getting that message and still nothing.
Skype wont sork either. I also tried Tango and it wouldnt work. There would be no video call option.
Just an FYI, on both 1/7 and 1/14, I'm still occasionally getting the MMC wakelock.
It came back on after some charging it was just something ran the battery down.Some app probably drained the battery, using the wifi to transfer data. Keep it plugged in and hold power to try to turn it back on every couple of hours. Or maybe the battery died, rare but possible.
Also, I noticed that maps was eating up the battery so I tried an old tactic I used to have to do with my Optimus V. I would put the phone into and out of airplane mode using the power button. This literally takes two seconds and after doing so causes my battery burn time to go from 7% per hour down to 3.5%. And that is without Juice Defender or Green Power installed. Maybe it is a CM7 quirk or something but I was able to reproduce those results with both 01-07 and 01-14 versions with the same apps installed. Hope that helps. Once again fantastic rom.
Thanks for that tip. I was wondering if there was an app to do that. I revoked the startup permission for some apps but they were still starting up.Clear Maps data in Manage Applications. That should stop it. If it keeps running just purchqse Autorun Manager from the market and disable Maps recievers. I disable every single reciever from every app i have and they never start up automatically anymore unless i open it. I get great battery life.
