hotalings
You don't need a task killer on any of the Triumph ROMs.
Agreed there is no need for task killers all the do is take UP MORE ram
Few questions. How would I go about fixing the video flicker issue and how would I use Titanium Backup before flashing the rom so I don't have to download all my Gameloft game data allover again or lose any progress in games.
There is no fix for the video flicker unless you use a stock rom. I can't remember exactly with titanium backup as I haven't used it in a while, but there should be an option in there to backup apps+data... The downloaded data will stay on your sdcard unless you delete it so you don't have to worry about that... Just backup app+data if you want to keep your progress.
i clicked the show button, and you gotta point lol. if i can click the show button, i can click the thanks button![]()
Followed all of the directions. Got everything reloaded. TT said to reboot so I did. Now the phone is rebooting itself every few minutes. Whyzor - earlier you mentioned Incredicontrol and adjusting some of the voltage settings. Any suggestions of what to adjust as I have never used that app before (and can;t actually get the phone to stay up long enough for the app to finish loading right now). Switched to a different battery so I don't think it is to warm of a battery. Based off of what you said before, it is either the voltage I can adjust with incredicontrol or the phone itself.
Any tips would be great.
With the new Kernel that was posted I still get a lot of touch sensitivity issues. I can especially notice it when playing games that require me to always have my fingers on the screen like Asphalt 6.
Should I restore them manually from Titanium Backup or the Market? I had been doing a batch restore of the apps and system apps.
Would you reinstall anything (free apps that don't backed up in the market) from TT or would you advise going through and just finding them all in the market again?
Could uninstalling titanium backup stop some of this rebooting?
This isn't a compliant or anything, I am just looking for an idea of priority. I know you are working through some battery drain issues and whatnot. Is the bluetooth and wifi together fail a priority for you? Is it even on your radar?
Whyzor, thanks so much for your continuing hard work on this ROM. I am waiting eagerly to read about your new release that has the functionality that I so need.
Basically, without the ability to run bluetooth and wifi together, I am sunk.
I am just trying to get a feel for the near term outcomes...
BTW, there are really only a few specific scenarios that I can think of where BT & Wifi need to be used simultaneously, like during a VoiP call over Wifi. Even then using a wired headset would still work. And setting up CM7's notification bar to have shortcuts to toggle both functions makes it easy to turn on/off.
It's natural to think "oh this ROM doesn't have a certain functionality that I need", but all phones & ROMs have problems, most are just not obviously listed on the main page and one will eventually come to them after some use. By then most will just stick with it because it's too much hassle to go back, just like it's a hassle to go to a new ROM.
