activeservo
Member
I noticed rom manager is included in the rom however the triumph isn't listed in the devices. are you guys using another devices name?
If you notice the time in his screen shot, it says 12:24 pmJust for kicks, I ran the speedtest also on default VM PRL, got 157 ping, 2 MBbps down, 673 kbps up. and another run gave 144 ping, 1.5 Mbps down, 637 kbps up. Keep in mind this is very late at night when most people are asleep. I think the speed varies throughout the day depending on how loaded VM's network is. I've gotten as low as 30 kbps down during business hours at work. PRL switching doesn't do anything, it's for Sprint roaming, and VM doesn't allow roaming.
I did a bunch of undervolt testing and I got the following semi-stable values for my device:
I found that 750 was an absolute minimum for voltage at the lower levels. Dropping to 725 or below resulted in a kernel error in the "OS Monitor" app about being unable to set the voltage. I imagine that <750 simply resets to default voltage, which is why everyone can run at 600 without issue (because it's really just the stock voltage).Code:[FONT=Lucida Console] 61440: 750 122880: 750 245760: 875 576000: 925 768000: 925 1024000: 1000 1113000: 1050 1209600: 1100 1305600: 1150 1401600: 1200[/FONT]
[FONT=Lucida Console]MHz A B
61440: 700 750
122880: 700 800
245760: 775 825
576000: 925 950
768000: 975 1000
1024000: 1175 1175
1113000: 1175 1175
1209600: 1175 1175
1305600: 1225 1225
1401600: 1225 1225[/FONT]
Whyzor, any chance you would accept a donated Kindle? CM7 works fine but has been abandoned for ICS development wich still has a little way to go before is usable.
I likely won't have time nor motivation to work on another device, thanks though.
I don't use juicedefender, do whatever's causing it for me is something else.I've learned that JuiceDefender is the cause of my mmc0, mm1 and mmc2 wakelock woes. I disabled its control over wifi and rebooted. I turned on wifi last night, did some surfing, turned wifi off and went to bed. The phone went into deep sleep for 8 hours, so I consider this issue SOLVED!
I'm going to send an email to the JuiceDefender guys to see if they're disabling wifi in some strange way.
Weird..... I finaly flashed cm7 for the first time and it seemed really laggy? I rebooted a few time thinking that might fix it but it didn't. I didn't change any settings and let it sit for 15mins then rebooted again and still lags alot. Probably my phone just doest like
Notes:
Austrie Recommends the use of "Incredicontrol" app, "Startup Manger" app, & "No-Frills CPU Control" app from market!
This kernel now contains the Isaac's fix for better HD gaming, therefor losing 30MB RAM.
Undervolting frequencies higher than 1.0Ghz MAY causing bootloops.
I have lowered the WiFi Voltages, and also Increased Volume; these are experimental. Watch these changes and report any bugs.
I have increased USB draw amount/speed, meaning faster charging via USB Charging.
There a couple volume boosters on market, "Volume+", "Volume Boost", and "SoundBoost"
Make sure to recalibrate your battery, read this thread for info: Correct Ways To Recalibrate Battery - Better/Accurate Batttery Life
To 2-Way Call Record you need a separate app from market, called "CallRecorder" by skvalex, here is his DEV thread: [DEV] Two-way call recording on Desire [ALMOST SOLVED][Sept. 7 update] - xda-developers
There is a DSP Manager for MIUI, link: DSP Manager Equalizer for Android - xda-developers
I believe it's in system/etc/firmware/wlan/qcom_cfg.ini. And I believe the line you're looking for is "gTxPowerCap=30." You would then change the value 30 to your desired value. I may be wrong, but this was what was mentioned in the original CM7 thread. I've modified this value in the past and didn't really notice any substantial improvement in battery loss or decrease in the performance of the wifi, though I didn't really do any significant testing, so there may/may not be any merit in modifying it.Searching is not turning anything up![]()
with the touchscreen having its own pipe line now would that have fixed the problem of some games like shadowgun where the character flips around and what not because of points colliding?
Was trying to use Groove IP with Google Voice at work with the bluetooth over the wifi. The Bluetooth and Wifi seem to still be trying to battle for supremacy. I can get them both working together on the Fidelio dock but the headset/wifi/Groove IP combo seems to not be a go right now.
