For the past week or so, I've been having an odd problem occasionally. Every now and then, the status bar will freeze. I can pull it down and push it up, but I can't use any of the power control buttons, and I can't tap or clear any notifications. It's always solved by a reboot or by killing the status bar process, but it's really odd and kind of annoying. I just updated to the latest build yesterday, and I even tried running a fix permissions in CWM. Any idea what could be causing this/is anyone else having this issue?
+1
Almost exactly this, except mine only started since the latest 1/21 build.
I wiped dalvik and cache and fixed permissions before updating this on top of the 1/14 build. My first boot failed, so I battery pulled and rebooted to CWM and reinstalled it again. Then the first boot was successful, but I forgot to add gapps, so one more time into CWM and installed gapps again. Now the notification bar sometimes becomes unresponsive as above.
I am tempted to do a wipe and clean reinstall of everything...
probably about time. But this it the only niggling issue.
i know this might sound like another personal request, but this bug alot of people one here. so it wouldnt just benefit me. thankyou
I haven't been bothered to change the head unit in one of my cars. It came with a Monster tape adapter. Doesn't do it with all songs, just certain bass heavy ones.
... I haven't tried with anything else though so yea... Maybe its your speakers? Or the tape adapter?
