ok im having 2 problems...
1. the prox sensor not working.
2. google music f/c alot and gives me black screens
Mine works, but there is a short (1 - 2 sec) delay as someone reported above.
Thanks Whyzor for all of your work on this ROM!
Dunno if this has ever been brought up but i was wondering if it was possible to make the screen brighter? Even with the screen brightness all the way up its still hardly readable in the sunlight while driving down the road. My wife has a Motorola Droid Bionic and hers is a lot brighter. I know that her phone is a more expensive phone and has better hardware but i was just wondering if it was possible to say change something in the kernel or source to be able to allow u to brighten the screen up more.
It is my first experience of Sleep of Death on my phone since I first switched to CM7.
Had an SOD on the 02/02 build as well. Wiped data, flashed the 02/18 build,set up the phone and keeping my fingers crossed.
Whyzor was referring to the screen protector that comes on your phone from the factory. You may not even realize it's there, but it is, and it doesn't have a lot of fans around here. Most people find that the display looks better and the touchscreen is more responsive without it.Oh aight thnx. I kinda figured it was a hardware thing but beings that u can adjust most everything else like overclocking and over/undervolting i figured there might be a way. I dont use any screen protector or anything but i guess i can live with it. Just something ive been wanting to ask about.
I too have been plagued with Sleep Of Death problems for a while through several revisions of Reloaded Rom. since i have not seen discussion about it here i thought it was something unique to me and had been pulling my hair out trying to figure out the cause.
NOTE: SOD is NOT about screen going blank after a call. It is when the phone refuses to wake up from sleep. i.e. unable to turn the phone back on via power button, requiring a battery pull.
there's no outward sign that anything was wrong. the notification light could still be blinking if there was message waiting. i won't find out that it's dead until i try to turn the phone back on. it has caused me to miss unknown number of calls... i also noticed that when the phone is in the SOD state it will not charge and the indicator light will not come on solid as normal when power is plugged in.
SOD seems to be completly random and seems more likely to happen after phone calls. (although i am not 100% sure about that point.)
if i remember correctly in the early days of CM7 we had similar problems with SOD when wifi is set to turn off when screen goes off. it was resolved by Tickerguy later on. i wonder if it could be the same bug creeping back in due to some of the optimization done in Reloaded Roms.
It might also explain why the problem is not wide spread and reported, as not everyone uses WIFI extensively. (i myself uses JuiceDefender to turn off/on wifi automatically and travel between several different WIFI access points during the day.)
i hope this brings some attention to this apparently rare but crippling bug...
also, as it hasn't been said enough: Thank you Whyzor for your amazing work!
Thanks Whyzor for all of your work on this ROM!"http://androidforums.com/members/whyzor.html"
Yes, I asked that a couple days ago, and would love to get that working again.How do we set the screen to dim before it goes completely off?
It's interesting how you don't realize how important some features are until they stop working.
I just flashed this, kudos. It's awesome. A problem I'm having though, is that Facebook, GMail, and other social networking style apps keep crashing on me. Anyone know what could be doing that?
It's annoying that the screen shuts off without warning, and I keep having to reach for the power button to turn the screen back on, instead of just tapping the screen when I see it dim, when I am trying to read these forums and such.
I had a problem today with my browser not rotating today.
I can set the "view in landscape". I checked my acceleratormeters with "phone tester" (it's in the market). They work.
Diagnosticly I don't know how to narrow it down.
P.S. a reboot fixes it. But the geek in me likes to have long up-times
88 hours before the reboot.
The autodim may have something to do with auto-backlight settings some of you changed with the latest settings aricblunk posted.
If you want the screen to dim automatically, go into the custom auto backlight settings and set the dim level to 20 or 16 or whatever you like. I'll go back and add that to my post, I probably should've thought about that earlier.How do we set the screen to dim before it goes completely off?
If you want the screen to dim automatically, go into the custom auto backlight settings and set the dim level to 20 or 16 or whatever you like, something lower than the 26 minimum when you're in a low-light environment too dim for the sensor to read as any darker. That way you have a warning before the screen goes blank. I just personally prefer not having it dim because I don't usually stare at the screen for more than a minute. You could also just go to Settings > Display > Screen timeout and set that to 2 or 5 minutes instead, so you never have to tap the screen to keep it awake.
I already tried that, with various settings, and it still didn't dim before going black.If you want the screen to dim automatically, go into the custom auto backlight settings and set the dim level to 20 or 16 or whatever you like.
