TheBritton
Resident Galaxy Cat
On the performance setting. Would that cause it?
Just recleared the cache settings and reflashed. We'll see how it goes!
If you're overclocked using the performance governor then your CPU is locked at the highest speed enabled. I wouldn't recommend the performance governor for any overclocked frequency and especially anything over 1.4gHz.. and really I don't imagine it would be good to use the performance governor as a daily default unless you're doing some benchmarking.. not to mention your battery life will be absolutely obliterated.
