Root [ROM] CM7 TG-Reloaded (Final: 03-25)
Well, I know CM7 could never deep sleep with wifi on this phone, but I noticed Tickerguys wording of "one level above deep sleep" and didn't know if there was difference between "one level above" and "awake".
I honestly say that I have left wifi on all day long with TG B.08 and idle drain was usually 4% an hour even though it technically never entered "deep sleep".
Just figured it wouldn't hurt to ask questions. I'm not complaing :)
Soon as you get HDMI working, I'll get it :D sounds real good. but lack of HDMI is a real deal breaker....
CM7 really doesn't have support for HDMI out.
Without a legitimate source code and drivers being released from Motorola, I wouldn't expect HDMI to be working on any ROM at LEAST until Cyanogenmod 9 is released.
Cyanogenmod 9 may very possibly have support for HDMI (the last time I researched it) :D
+1 on thunderprop AND...
Please add InigoMontoya's gps.conf file.
thunderprop won't happen, you'll just have to install it yourself, it changes the way Android market recognizes the device as something other than Triumph.
The gps.conf file will be in the next build, it only adds a few extra info, such as the NTP server as north-america.pool.ntp.org & also enables agps (not sure if it even works on the MT according to TG). I already get GPS lock without network help in about 1-2 minutes cold, and then a few seconds afterwards warm.
Sweet, what's the ETA on CM9? A safe estimation.
Which ROM is better this one or MIUI? This one seems better but MIUI seems like it has the capability to be faster. Any screens for this ROM?
Been busy playing with my Kindle. (shameless plug) but just wanted to say I had some very bad battery drain and overheating issues after flashing that did not happen after flashing back, happened after flashing the latest OC Kernel also. Yes, I flashed twice both with separate downloads of the zip. Anyway yesterday I just did a clean install and wiped data before flashing. Did a batch restore with Titanium, restored data for a few basic system apps like contacts, accounts and hotspots and did a permissions fixer and all has been fine.
Also as far as issues pertaining to tethering with other Android devices, I’ve been tethered with my Kindle for the better part of 48 hours and have not had any issues. Seriously though, best 200 bills I ever spent, is too sweet Rooted with the Market and ADW. (Shameless Plug)
I'm so glad someone picked up development on this!! Here are some of the issues that have been bugging me, if anyone else has had them please chime in so we know it isn't unique to my phone.
1. Slacker and stock music player turn down the volume when I get an email, and it doesn't go back up until I pause for a few seconds. I get a ton of emails so this annoys me.
2. It seems like WIFI takes a really long time to connect, but as soon as I go into the wifi settings it goes really quick. Maybe I'm imagining it...
3. Back button sometimes stops working for a few seconds. Going to the home screen or hitting other buttons seems to fix it.
4. Auto screen brightness doesn't seem to work that well. Maybe the sensor just isn't great, but it doesn't seem to go to max brightness when it's really bright out or, conversely, go to the minimum brightness when it's pitch black.
Maybe there are tricks, or apps, or some way around these problems, maybe I've got a bad install (I've done several clean installs along the way so I don't think so) or maybe they are actually bugs in the ROM.
Here's a very, very easy fix that has been bugging me regarding the ambient brightness sensor and CM7's custom automatic backlight option.
The default Android automatic brightness (non-CM7) didn't adjust brightness while the screen was on for me (only upon wake), so I went into the CM7 settings and enabled the custom automatic backlight and button brightness setting, using my own values. However, when the sensor reports 0 brightness in merely moderately dark conditions (like my room at night lit only by my monitors), the CM7 custom auto brightness function seems to detect this as invalid data and ignores it, keeping whatever averaged brightness it already had. This means that when I wake my phone in brightness and then enter a dark environment, the phone will never drop down to minimum brightness levels and simply stay at whatever it was before the sensor started reporting zero. My guess that fixing this would be as easy as just adding 1 to the ambient light sensor's reported value so that it's not reporting zero in darkness and being ignored by CM7's custom auto backlight function.
Of course, the real fix would be to figure out how to get more precise data from our sensor (not that I expect that this is possible) so that we're not just multiplying its output by 30 to approximate actual lux values. Because our sensor reports a small range of values (from 0 to around 50, where 0 really isn't all that dark and 50 is direct sunlight, according to our sensor's raw output) we have very grainy data, and I set my minimum screen brightness and dim level to 26, as that's about how bright it needs to be when the ambient brightness is just below the point of prompting a value of "1" from our sensor. However, this brightness is still temporarily almost blinding when the eye is adapted to much darker environments, like an unlit room at night.
Thank you for continuing development on this great ROM, it just keeps getting better and better.
if you cant get it let me know and i will change it for you
I wasn't able to change the carrier name, if u or someone else could change it for me that would be great. I plan on flashing the latest build out now Build 20111230
(i tried to put the edited framework.res apk into the framework folder but then i get a window popping up saying "compressing" then another one pops up saying " the compressed (zipped) file is invalid or corrupted"
also is anyone else having problems during a call? my phone keeps vibrating every second while im on the phone talking.
suggestion: can you try to fix video playback while the phones orientation is vertical?
The accelerometer works, video drivers work, I can watch videos just fine using MX Player. This is probably a player app problem.
CyanogenMod 7 is an open source ROM and more widely used. It supports theming, so it can look like almost anything you want (including ICS), just have to search for those themes after flashing the ROM.
I've noticed this occasionally, maybe when switching to a new hotspot. Usually my notification bar wifi toggle works, if it's taking too long I'll go into settings, and if it still has problems, I forget the SSID and reconnect (rarely).
I've noticed my capacitive buttons on the bottom sometimes freeze for a few seconds (not just back button, home & menu too). Probably some mutex_lock somewhere in the OS/kernel. These types of problems are extremely hard to debug.
Auto-brightness on most smartphones don't work very well anyway. I just turn it off and setup CM's setting for changing brightness by dragging the notification bar. Or use Aricblunk's suggestions. You can customize it in Settings - CM Settings - Display - Automatic Backlight - Use custom & edit other levels.
See this article for what I mean: Why iPhone 4 and Android Brightness Controls Are Effectively Useless
Nope, not seeing this problem, maybe you have to re-wipe and reflash, test it out before restoring any apps to see if the app restore step is what's introducing problems.
I'm noticing that when connecting to a non-broadcast SSID my network appears to be disconnecting frequently...any ideas?
Hmmm...
I thought that the video "flicker" thing in portrait mode was a very well known bug in this ROM. I just installed MX player to test (been quite awhile since I used it) and it seems to have the same issue. I've just gotten in the habit of using landscape mode as a workaround. Not that big a deal to me because portrait kinda sucks for video anyway.
Hmmm...
Ok, I just rechecked and it appears to flicker in vertical mode in MX Player playing a MPEG4 compressed video file, xvid works fine. So I'm guessing there's something wrong with the video drivers or codec. Not sure if I can do much about that, it's pretty low priority too since there are many workarounds.
Wireless is being very flaky.. it will show connected but i'm having to shut off wireless/turn it back on to get it working....
Does Amazon appstore app work?
I am keep getting can't verify the payment method on a free app.
I missed a promotional free deal.
Is it my account or phone?
