Does Amazon appstore app work?
I am keep getting can't verify the payment method on a free app.
I missed a promotional free deal.
Is it my account or phone?
Do you have a registered payment method? Amazon won't let you download anything, even free apps without one. I have amazon on my phone running this and have never had a problem downloading apps.
Wireless is being very flaky.. it will show connected but i'm having to shut off wireless/turn it back on to get it working....
Anyone else having problems with the rom rebooting a lot? it works great once I can get it to stop or as long as I never turn the phone off and try to restart it but if I turn it off for awhile and then turn it back on it reboots every few minutes.
It was running on the default interactive setting. I haven't made any changes since putting the reload on. Like I said, was working great until I shut the phone off and can't get it to stop rebooting now.
Restore backup and try not set your min to low with this new interactive governor this time...
The past couple days I've encountered the no deep sleep bug. I flashed this release the day it was updated and it's been fine. Then about 2 days ago I pull my phone out and it's half-drained and really warm. After some trial and error I figured out it wasn't going into deep sleep. If i reboot it fixes it, but several hours later it starts again. I'll try a clean reflash at some point, but just a heads up for you.
Wondering if it might be battery temp related. After the phone was on my desk with all the data off for awhile etc. it just stopped rebooting and is fine now.
Mine did the same thing with tg build and OC kernel (not this build) reboot a million times then work fine if I let it sit...I wiped everything and reloaded tg last build and it works great again...afraid to reload oc kernel...just wanted the touch screen fix anyway
A user were talking about the old one being more reliable, (I think it was you), but the new one is better for dual stick, and the new one cleans up the garbage build up that was in the driver.Just curious, what did you notice differently with theOC's touchscreen fix? I've been looking at the code & the stock (TG's B08 version) of the driver works the same as theOC's (Isaac's new version). If anything the older version is more reliable.
I'm the same way. I like to keep as little crap running in the background as possible. Just to make sure, I installed watchdog and there are indeed no runaway apps running. And I have been checking cpu spy regularly. When it does stop going into deep sleep, it idles at my min frequency, 122. I'll check out BetterBatteryStats and report back when I encounter it again.The fix I added was to prevent MMC kernel wakelocks, it's entirely possible that you have an app or a setting that has another wakelock that prevents deep sleep (such as the known wifi or BT on bugs). The only helpful app that I know of that shows "partial wakelocks" and "kernel wakelocks" is BetterBatteryStats, and in the 'kernel wakelock' menu, you'd see how many hours it was awake and should show 'MMC2', MMC1, MMC0 (to prove my particular fix still needs work). Any other leftover kernel wakelocks (and there may be a lot) would require a new fix. But I haven't encountered any other type yet, I don't install a lot of unused apps on my phone either, so that's a good baseline to gauge whether the ROM has issues.
Using CPU Spy app can also clue in what's going on, if it doesn't enter deep sleep but idles at the lowest frequency, then that's the same problem as my MMC fix was supposed to address. But if majority is spent at higher than min freq, then it points to an app or runaway process that's keeping the phone awake, which is a different problem.
Anyone else having the screen flashing on/off during a call?
I had this problem with earlier TG builds, as did many others. He did something to fix it and it worked fine (at least in the 0.8, I don't recall when it started working again). Now the problem seems to happen again (to me) using this ROM.
I'm not sure if it was me, because I just came to this conclusion yesterday. Up until yesterday I had been using kernels that had Isaac's updates, then for kicks I switched back to stock touchscreen driver (used in TG's B.08 kernel). They're both functionally the same (see Isaac's comments here). The Touchscreen interrupt service call gets run many times a second, so a more efficient code path is actually better for smooth gameplay & overall use (at least in theory, and somewhat confirmed with my limited testing so far). Here are two kernels, for those who want to test differences between the two, make a Nandroid backup, then flash one, test playing some games, & use a multitouch test app, then flash the other one, and repeat the same test procedure, let me know if you notice any differences.
Kernel using Isaac's Touchscreen driver
Kernel using stock Touchscreen driver but optimized
So you know how to code, that nice. Where did you learn from? I would test it for you, but, i'm on MIUI.
lol, yes I know how to code. I have a degree in computer engineering, my day job is a software engineer, but only dabbled in some embedded systems as an intern in college years ago. I haven't done much with C/C++/Java in a while, my day job uses mostly scripting languages. This project is really pushing me to keep my skills sharp![]()
anyone else still having deep sleep problems? Even in airplane mode a lot of the time it won't deep sleep. Until I reboot, it just won't deep sleep. I'm using the latest update.
