dsmryder
Android Expert
regarding the soft key lights (capacitive buttons), is it possible to make them brighter?
That would be under cyanogen settings, display settings, automatic backlight, custom levels
but I was just wondering if anyone else had the color of the status bar (signal, battery, 3g) go from blue to green? Originally when I flashed, everything was blue including the overshoot effect. After a couple hours it reverted to green & the overshoot was yellow. I don't think there's any other problems (besides the proximity sensor during/after calls) so is this just a glitch? I looked through all the settings to try and change it back, but came up with nothing.
anyone having issues where the audio skips every so often. It could just be me messing with the ROM lol. I have tweaked it alot since I have installed it, moving the dalvik-cache to /cache/dc, adding my tweak script, adding some build.prop tweaks, using musicmod v1.8 along with other things. Just wanted to see if anyone else experienced it on the latest TG-Reloaded build!
AppExtractor from the market is awesome for restoring everything the way you have it before.
I used AppExtractor with the paid key and it only backed up half of my apps (a lot are still missing after trying to restore a couple times). Most of which the data is completely missing. Mostly game data is all missing. Had all "Where's My Water" complete and lost it all. Emailed the developer twice with no response. So, if you do use AppExtractor, also use something else to make sure you can recover all of your apps and data.![]()
Just a possible face palm on my part are you planning a cm7 by Brandon 14 if so cool man.anyone having issues where the audio skips every so often. It could just be me messing with the ROM lol. I have tweaked it alot since I have installed it, moving the dalvik-cache to /cache/dc, adding my tweak script, adding some build.prop tweaks, using musicmod v1.8 along with other things. Just wanted to see if anyone else experienced it on the latest TG-Reloaded build!
Just a possible face palm on my part are you planning a cm7 by Brandon 14 if so cool man.![]()
It doesn't back up apps does it? I thought it only pulled data from nandroids...
Can I flash this 3/25 over my older 3/04 without clearing? ..or will that present problems?
Not sure if any one has had this problem but auto rotation wasnt working for me on 3/4 build went to 2/18 and it works now any way great work thank you for you on going work wish i could build like you.
I just noticed this ROM, I haven't been paying attention since Tickerguy left, and I was wondering if you could answer a couple of quick questions.
I currently have the Final version of Ticker's ROM installed and it's working wonderfully. But looking at the changes to this ROM make it seem like something I'd really be interested in installing.
1 - Are there any "downsides" to this ROM over TG's Final one? I see most of the same "Known Problems" listed, but I just want to make sure.
2 - I currently have the Thunderbird Prop file or whatever it's called currently installed (sorry, I'm not great with all the terminology) so I can install apps, like Gameloft ones, that supposedly aren't compatible with the Triumph. Is this something I could install with this ROM as well?
3 - The BT and Wifi preventing deep sleep. Is this something that is also present in Tickerguy's ROM? Perhaps I just never noticed it. Does Wifi actually have to be toggled completely off manually, or could it be done with a program like Tasker or some sort of battery manager?
Thanks, sorry if I'm asking obvious questions.
Toggling Wifi is the same with any program as are as android system is concerned. There's no difference in how you do it.
Hmmm. Me too. I just noticed it. It was blue when I flashed it, now it's not.
Go to the theme chooser app. The default theme of this rom is cyanbread which has blue icons, but if it got switched to androidian or system theme, it will be green. You may have uninstalled it, in which case you will have to download it somewhere or get it out of the zip file from the rom under system/app/
You'll go blind!**now my only problem is i cant stop playin with my phone lol
Well I have got a stable bROM release right now so I'm trying to mess with my bKernels. But I have been thinking about starting my own flavor of cm7 for this phone. Don't hold me to it but I'm thinking about it. I've been running cm7 for a couple days just playing around with it. I'm mainly focusing on my kernel right now!
