MediocreBadGuy
Yes it goes back to the exact same way you had everything at the time of backup.
No, it does not have an edit button, but because of the way Android manages memory there eealy shouldn't be a need for one. But if you feel the need for one, go to Settings > Applications > Development > Stop app via long-press which allows you to kill an app by long-pressing the back button.I just flashed this ROM and noticed the default browser doesn't have an exit button. I looked for a way to add it but wasn't able to find anything. Am I missing something?
Whyzor, can you refresh my memory on what the default minfree settings are on this rom?
Hey Whyzor, is there a way to disable S-GPS in the software for testing purposes? I have a hunch this may help with the GPS knocking data down to 1x. check this out: S-GPS - Wikipedia, the free encyclopedia
It's a listed feature for the triumph
So it would have all my apps already installed with everything sync on that from the last time I did the NANDROID backup? or would I have to re-install al my apps like when I put on CM7?
Could you take a look at the 2.3.4 WIP ROM? It has almost everything working (even HDMI) only thing it really needs is Data fixed and a few other bugs. Would it be possible to port the neccesities into CM7/9?
Its not too far off from completion just got Triumph's Ril working on it
- could use any help you can give Whyzor![]()
Not to put off all your hardwork but I really like CM7's UI and customability better than stock GB![]()
Heading explains question.
Go SMS used to allow me to customize the notification alert sound for individual users.
The SMS message sent by VM every month was one that I silenced. The first month it woke me at midnight, and I decided that it should be silent.
Recently, I wrote a monitoring program that sends SMS messages to my phone, and wanted to change it's alert to something more obnoxious than my default, but was not able to make anything work.
Tonight I got my VM SMS alert around 10pm, but it was my default SMS alert sound.
Anyone else experience this with this latest ROM and another SMS or using Go SMS? Wondering if I should submit a bug to Go SMS or if it might be something new in cm7.
Thanks.
The only thing I changed recently was to remove a number of rom applications that I never used.
I did get rid of the default SMS, browser, and adw.
I thought it might be aggravating the SMS issue, so I finally removed them.
MMS works fine for me when I uninstall the stock Messaging app.I thought that the default sms app was necessary fot mms to work? Could someone tell me weather or not that's true?
Does anyone have issues with incoming calls? At least 2 people told me that sometimes they can't call me
My phone goes into deeps sleep sometimes and it doesn't come out of it (sleep of death). It happened on the stock ROM, it still happens on this ROM. When it happens, the led still blinks but the phone is not working, so you're not receiving calls, texts, voice mails, emails. You have to pull the battery out to get it working again.
