That did not work.
how didn't it work? it adds the apk back like it was never removed
does it have to have the vpnservices.odex in the folder also?
your getting the VpnServices.apk your trying to add out of the RemovedAppsGB.zip right? there is no odex files cause the rom is deodex'd
No I download a GB 2.3.5 stock app pack and used it from that.
Thanks you the man!!well theres your problem =p
read the first post of this thread
Hey blood, I drive truck over the road and have a quick ? Which of the apk packs / or other programs do you recommend I install to get voice activated dialing thru my bluetooth headset's mic working again. Its very important I have this feature, because it is now illeagal nationwide to use a phone in a commercial vehichle without a hands free device while driving. The fines start @ $2,750.00 and that would really put a crimp on any future donations! lol.. I wanted to ask u b-4 I put something on my phone I really didnt need.. Tx
Again, my phone is awesome and I thank u for all your hard work!
"GaToR"
I don't have a bluetooth device so I'm just guessing here but try VoiceDialer.apk. hopefully that works for you
Bloodawn, first of all, thank you for this beautiful and lightweight ROM. I actually find that my best experience on a phone so far is with my Prevail + CTMod. However, I'm noticing that the biggest drawback to the Prevail is its rather tiny onboard storage capacity. I know other mods can "force" SD storage of everything. My question is this: is this too complex an addition to CTMod? Something like this would simply move my phone from excellent to heavenly.
Everything was working fine but all of a sudden my market stopped working. It keeps saying server error. Everything else that uses the internet connects without any problem. I have the same apps that I had when my market was working, except some have been updated. I tried downloading ctmod 2.4 again, unzipped it and copied the vending.apk to my system/app folder. Still won't connect. Anyone have any ideas?
BloodDawn how do we keep our apps from the market and all of our contacts and such? I have installed you rom before and lost everything and had to revert back to the back up to have these things again.
Also I have made myself a costume theme for your rom and I tried to load the theme I made over at The Kitchen and it wont take it. Is there something i am missing here?
Thank you.
I just installed CTmod2.4 and Im currently stuck in a boot loop. I see you said it should take about 5 minutes the first time but this boot loop has been running for a while. Perhaps I need to restore at this point I suppose?
hey blood if you dont mind me asking...what did you use to make your simple themes?
Thanks man, I will definitely take a look into that.There are scripts and apps you can accomplish this by. I am personally using darktremors apps2sd script and it works like a charm. There are other alternatives and there is a thread comparing the two big ones.
contacts are linked to your gmail account. when you log back into the market they will sync
you either have to reinstall the apps from the market or use titanium backup. if your already on CTMod and upgrading to a new version you can do a advanced restore in CWM and restore /data
did you upload framework-res.apk and SystemUI.apk from the rom to the kitchen?
Yeah I did that but I still can't get them to work. I took a look at your theme WP7 Style 1.1 and it's diffrent then what was made for me. I think I did something wrong but it did say it was good to go. Are there settings have to use only?
