Root [ROM] CyanogenMod 7 Huawei M835
Are you downloading from your phone? Is it giving you an error code or anything? What exactly does it say?
Yes I did download it on the phone seen my laptop
Is dead. Now I can't even do nothing it just boots up
And stays on the huawei screen. I don't know how to get it into the recovery
My girls friends laptop don't even say it's on or nothing.
When I did use the rom it said abort and didn't load the rom.
if you pull the battery out, hold POWER + VOLUME UP + GREEN BUTTON, AND INSERT BATTERY YOU WILL BOOT INTO RECOVERY.
iam sorry you are having troubles, as i test these roms before i upload them..
maybe toggle signature off and assert off
are using the android kitchen? its reall good for cooking ROMs with.
Yea I can hook ya up with some links on setting up to build for android. Github is a great source of help info too ;).
Do you think it would be safe to compile roms for arm6 in Vmware? or should i use actual hardware..
Thanksssss soo much you saved my phone from getting smashed lol.
So I will retry that one update of the rom and see what happens. It's just my wifi not working in 1.1 rom
Ok in cm7.2 m835-09162011 the wifi try's to get on but then says error.
A friendly tip. Do not set it as "set at boot" (the 748mhz build) in the over clock settings If your phone starts to reboot because of too high of an overclock setting, it will keep it at 748mhz when it reboots and you can go into an endless boot loop if you cant get back to the settings fast enough to turn it down and will be forced to wipe and reflash.
A factory reset from CWM will fix the bootloop ;)
re:choppy
pull-down menu aint smooth, on antutu, with the screen test things, its like stop-motion photography,
. 5 sec delay between letter press n character display, scroll in app drawer jumpy,
things like that
n while im here, to c if ur hardware support multitouch,
#*#*2846579*#*#
projectmenu
veneer information query
apparatus type query
gotta b on stock as gb loses hidden menus
under touch screen type, anything other than synaptics, multitouch wont work
I flashed the new Tom's you posted on android forums and then I rebooted my phone and it keeps getting stuck at on the boot screen with the 3 blue guys. Any suggestions on why it isent booting? And one other thing everytime I flash a Tom onto my phone it tells me that I don't have a sd-ext but that never stopped any previous versions from working. I thought before I started all the Tom flashing way back when I did the whole sd-ext thing. But then when I started noticing it saying that I dident do anything about it because as I remember. You have to. Wipe you're whole SD card to do the sd-ext to your card but please someone help me get passed the 3little blue men. Boot screen if anything. Please
This rom is good except for the camera part, also I can't get any video images when watching a video but I can get sound so is it just me?
As I was saying everytime I flash the 09152911 I get stuck booting at the three little blue alien looking things. So can someone please help Me out?
if you use rock player, you have to use it in software decoding mode, then u get video, still working on a camera fix.. it will take pix, just no preview
did you wipe the davlik cache... also did you download on a phone or computer.. it seems to be kinda hit n miss, i havent had any problems, but i will look into it.. for now, i would try the 710mhz 1.2..
