PlayfulGod
Extreme Android User
theres a bootsound binary and props in the etc/init.local.rc thats needed also. If you look in the cm7-ascend.zip you will find these files and if IIRC the sound file sound be name android_bootsound.mp3 and be located in system/media/audio/ui.I have been using the cm7 from December (page 5 in this thread I belive) and have gotten everything working -- there is no boot sound (which is ok) and I tried making. moving the build.prop file and an mp3 still nothing. I was finally able to get gmail and things to sync, and the resolution (or lcd density is at 110) - the only thing I can't get to work is the camera - it will take pictures, just shows a blank white page. anyone know about this?
And Flash will never work correctly or fully on the m835 for the same reasons as it will never work on the Ascend.
