Root [ROM][DEV][WIP] CyanogenMod 10 for the LG Spirit 4G
Need me to pull anything pg. I seem to always be running cm10 and would pretty much do.anything to contribute.
This may be stupid/already tried...but is it possible to take the S/W Decoder/Codec from mx player and put it in the default video player in cm..then set it to always play the s/w decoder...does that make sense :confused: I was playing with mx player and the only way to get vids to work is to use the s/w decoder so I figured it could be a temp fix for default
YouTube..Browser video playback now working!!
http://forum.xda-developers.com/showthread.php?t=1960117
Download OMX_libs_Update.zip
Extract/replace files to system/lib fix permissions to
rw-r--r-- then reboot..
Were they needing replaced or were they missing?? Either way good find I will be doing a new build soon.
I have some ideas on bluetooth.. first being to get CM to boot from its own boot.img (loki'd ofc) and not use 2nd-init. Rest I think is just getting the bt files and scripts to play nice.... or just rebuild em altogether. ;)
Working good for me. Stock video player freezes a bit but its better than nothing. That's what we have mx player for :D thanks for the great find.
Edit: let's not forget instagram videos play now :thumbup:
Dharp1996 transfer everything to system/lib folder..they files that have copy..keep those just remove the word copy fix permissions to rw-r--r-- then reboot.
