genovdot
Android Expert
do me a favor and do a adb shell getprop and tell me what it has for default network type.
After you change it to what works that is.![]()
If I had a PC I definitely would. Unless I could do it from the terminal emulator
If I had a PC I definitely would. Unless I could do it from the terminal emulator![]()
getprop > /sdcard/prop.txt
terminal emu will work. And to make it easier...
Code:getprop > /sdcard/prop.txt
Then just email it to me or attach the txt file here.
I'll then edit that in the system.prop for the build.prop.
Gotcha. Email please?
me @gmail lol
Got it. Be back in a few. Just gotta restore this backup.
thanks but it was ofno help. lol, Seems the prop isnt set at all. SO I will add the prop and enable what you said and get the needed value. Then I will do a new build to test to see if it works out of the box per say.![]()
I wonder if we will ever see cm 10.2 on this phone LoL
this is the spirit not the motion, works like a charm on the Spirit.PlayfulGod: which cwm?? hroarks sd-ext data one?? Because you do realize that even if you just boot to recovery, it will still factory reset.
Just flashed but still no data out the box . It was still on the same network mode as stock . Thanks still testing![]()
