Root [ROM]ELITE Series IV*ELITE Series Resurrected*Updated With Tweaks
ocnbrze
DON'T PANIC!!!!!!!!!
ok so this is a blast from the past sort of. this is an updated version of froyo's koni's elite series III. it was one of my favorite roms in the froyo days. and diablo67 has just updated it to the latest ota. i'm gonna give this one a try. and again this is not mine.
diablo67 said:
Ok guys this is Konikubs Elite Series rom updated with the latest OTA and the wifi is fixed.I kept everything intact,nothing was changed as far as the graphics/theme goes and no tweaks added,its as original as you can get.This rom is fast and smooth,so i hope you guys will like the new updated Elite Series IV.The actual problem i was having with the wifi issue was a corrupt driver.I also had to edit the market updater to keep the market from losing the transparency,otherwise it will update and go to the default theme.
Discalimer:I'm not held responsible for what happens after you download this rom,if you follow the install directions,there will be no problems.
Installation:
1)Download the rom to your desktop
2)Connect your phone to your computer
3)Drag and drop the rom onto your sd card
4)Right click the icon in your taskbar and eject your phone
5)Go into recovery and do a full wipe(everything,BUT SD CARD!!!!DO NOT WIPE SD CARD!!!!)
6)Go to flash zip,then find zip to flash and install the rom
7)First boot after wiping takes longer,but when you finish the set-up,go to system update and update your profile and PRL,then your golden.
Special thanks goes to the following for their commitment,help and donation to make this project successful:
Wgallt(Donator and beta tester)
Outerdepth(Help with the wifi)
Gruesomewolf
Channelog:
Added flashlight app
Added build.prop tweaks
Fixed market from updating and losing transparency
Updated kernel to OTA 4.67.651.3 Stock
Fixed corrupt wifi driver
Preserved original theme
Zipaligned apk's
Tweaks added:
Upgraded video recording and picture quality
Increased wifi speed
Decreased dialing out delay
Internet Tweaks
Render UI with GPU
Increased size of delvik cache from 32m to 64m
Increased scrolling response
Increased battery saving potential
Increased overall performance
Increased video acceleration
Apps added:
Flashlight
Good:
Almost everything works
Bad:
Black and white view finder(can't seem to fix this)
here is the original thread:
[ROM]ELITE Series IV*ELITE Series Updated
ok i just flashed this rom and man is this rom awesome. i love the theme and the wallpaper is amazing. wifi does not work for me at the moment, but this is a known issue. can't wait til all of the bugs are worked out. i'm glad diablo67 has kept the theme of the original as close to what i remembered it to be.
keep an eye on this one!!!
Thanks OCN! I saw this at XDA yesterday and I'm looking forward to it.
Nice that someone is updating some of the older Roms since I never got a chance to flash them.
Naters
yep exactly. this rom is gonna be nice when its is finally done. i really like this rom. it is very smooth and super fast as is with no tweaks or overclocking. might have to hold off though as i can't connect to wifi yet as that is my only source for the internet.
O mang, the Elite is back!!!
I loved Koni's Elite back in the days too, great rom. Will be flashing very soon. :D
Big D is really getting his dev work into high gear! :)
Now this was a real badass froyo rom. Can't wait for the wrinkles to get ironed out here. Hopefully the remake is as good as the original. I might even think about flashing the original at some point.
I wasn't on a smart phone during the froyo time. I was on a black berry at the time. Got the EVO it was already Gingerbread. Had it for a month before I rooted it. Then I went totally nuts and was like flashing 2, 3, 4 times a day. Now I'm more mellow and just flash when something catches my eye. I'm currently running Red Line right now and while there are a few minor things I don't care for its a decent ROM and working out good for me. I'll give this one a go soon. I downloaded it so its just a matter of naning and flashing.
The kick ass Koni is back and kickin!!!!
Here ya are Brent :)
Unfortuneately Konikub has moved on for now,he said he might return when things for him get ironed out,i got his permission to update his rom,since XDA elected me for the update,since my Red Line release worked out so well.It takes alot of research,concentration,trial and error.Anyway i'm working hard on this wifi issue,as soon as this gets fixed,the rom is golden,it will be ready for daily driver status.I have Wgallt helping with the testing,hes using the rom now as a daily,he has 4G so he said he does'nt need wifi,lol,but its being tested daily for other bugs,none as of yet.Be patient guys its coming.You can test this beta if you want until then,the more testers the better.
thanx diablo67 for taking this on. i really loved this rom when it first came out. and you have stayed tru to the original rom from what i remember of it. this rom is awesome. no complaints what so ever with the design. if you can get the wifi issues solved, this will be my daily for awhile (or when i find an ICS rom that works for me:))
Nice glad you got the WiFi issue straightened out.
Personally I rarely use it so not a deal breaker for me.
I flashed this last night. It looks really really nice. I never saw the original one so I can't compare them.
A couple of things I noticed. Even though its based off of 4.67 it's GB 2.3 not 2.3.5. Also it doesn't have the Power save feature you can find by using the Search button in settings like you can with 2.3.3 and 2.3.5.
I'll run it today. Thanks again!
Edit: forgot to mention there doesn't seem to be a native screen shot.
Naters
Ok guys i got the wifi issue fixed,it will be posted on XDA in about 20 minutes,its 6:13am EST now.Enjoy.That way you can update this thread for your members.
Thanks Big D!
We'll get the updated version added to the roms and kernels page. Also of you don't have time, one of the guides can update the OP for you. Just let us know. ;)
Naters
I ended up trashing that boot.img,it was corrupted,i had to find a new kernel and drivers.Its all good now.
Thanks Big D!
Anytime and thanks to you guys.
thanx diablo67 man i just downloaded mikg3.1and now you have the wifi fixed for elite? damn! which one?:confused: i guess i will try them both. lol:D
I just downloaded and am getting ready to flash! Ive been using Mik3D for a while and loved it. From what I read about this and what ocnbrze says, it sounds really good!
Well I havent know diablo for very long but I do know he is a commited dev and solid. His Red Line rom is a great ROM as well. Even though admittingly for me its a little to Red. Still is currently my daily though. I do hope he finds the time to keep it going. Its really good to have devs like him who are also members of the forum.
Yeah, it is very nice. It has a little bit of blue and runs very well.
It has the Notification options to turn on/off 4g,wifi,BT,data. and other stuff.
I'm going to run it for a few more days before I try MikG V3.1.
I could see myself going back to it down the road to and if Diablo adds the tweaks to it as some would like it will only get better.
Naters
I am impressed so far. I have 1 app (real estate related for work) that I cant get to work, not sure if it is an error I made or not. Will find out tomorrow and report back.
Otherwise, pretty slick and very quick & responsive.
