So once I flash this ROM, whenever I install an app it will automatically run from the sd card?
I've been running it all day with the Max at 633 and now apps are taking forever to open and some force close. Gonna try a wipe and reinstall.
Cool, thanks. I'm gonna do a nand backup and try flashing this over 2.03. I'll let ya know if it works.
EDIT: Flashed over 2.03 and the only thing I notice that changed was the battery indicator. Everything seems to be working ok, including a2sd and OC. Question about overclocking, should I have the max set at 710Mhz or will that mess up the phone?
You have to install setCPU (costs 1.99 in Market).Just flashed this rom. Evertything seems ok. But i cannot figure out how to OC...
Where is this setting? Or do i need to flash another file?
Anyone else notice that the awake time is 100%? Is this due to the overclocking? Seems to drain battery pretty quickly...
The eris is not on the list of phones.
Does it matter which one we select?
Thanks. One more question.
I flashed the dialer key update, but didn't notice a change.
Is there another step I have to take?
Love this Rom so far!!!!
Dialer update was already added into the rom when I updated to the new version so it would not have done anything but thanks for bringing that to my attention so I can remove it from the post. The battery updates will still switch between the different battery indicators so you can pick the one you like.
Setcpu is free to members of xda if you want to go over there and look but it never hurts to support the dev if you want to get it from the market. I hadn't noticed the awake time but my battery life has been good. I will look at it later cause I am testing another Rom I'm making.
