Thanks Conan! You the man! Lemme know what you find out.
Also still noticing a bit of a lag. I have OC set to 528min 710 max. What are your settings Conan, since they seem to be working for you? Thanks!
I set mine to 710/710 and have performance on. I also put up a version of this rom with Sense removed and OC, Jit enabled, its pretty quick if you can live without sense...its won't be as stable as this one but I have been running it for a while and only had 1 or 2 reboots so its not real bad. you can check it out here if you want....ErisLightningBolt1.0 I'm only posting it over there cause its a pain to have to update 2 threads everytime I update something.
