ROM [GB27] Project X v3.9 {Team Rejectz}(Updated 01/06/14)
Ok so how can I know it's a good copy...... Can I start over brand new with this somehow and just restore back?
Good copy? If you installed v3.0 then it has the keyboard in the system partition which caused my lag. If you flash the mod (space fix) it will relocate the keyboard to free up space on the system partition, which fixed some problems I had with it being sluggish
:thumbup::thumbup::thumbup::D
  • Like
Reactions: Doc
sry to be a pain, but can list the process to do this clean and right? like do i need to start with the 1st edition of project x and then keep doing the upgrades?
No, start with v3.0 -- use EL29 direct boot.. use 2x jb wipe in recovery.. then flash v3.0
Let the rom install and boot, set up your gmail or w/e.. then go back into recovery... then flash the space fix..then reboot..done
if you want, you can upgrade AIO mods from 4.3 to 4.4, just do that in a separate recovery ( not the same time as the space fix flash, I did this and ended up having a bootloop ) .. then your up to date
Shezzy, do you mean the weather widget or the red clock up in the middle? Both the weather widget and ability to center and change the color of the clock come from 3.0
whats space mod?
Think the space mod is for if you are using default xperia keyboard graciously included in Project X. There is link for a space fix for the keyboard size over in xda. Think that may be what is being referred to.
Thx for the suggestion. Seems like everything is ok now. Used voltage control to save the settings to init.d script and the settings are sticking and no double boot ups either :) thank you sir!
Depending on how you tap that weather/clock widget in the highly customizable xperia launcher bilgerryan includes as part of Project X can have it 4 by 1 or 4 by 2, and it folds out when you tap it on the screen. Maybe ya already found it Shezzy, and reckon that's whatcha were asking bout?
Yep I found it..thanks
I actually didn't go with it because I'm OCD about my battery and I didn't like the animation in the widget ( reminds me of power hungry live wall papers ). Instead I am going to use weather bug elite and just freeze it with titanium backup. Sticking with the 3x1 clock widget
That's with 3.0 brother. Did you try the cpu reset bilgerryan mentioned yet? My ace arrived today picking it up hopefully. How do you want my xtra stock battery sent?
