bilgerryan
Project X v3.6-http://forum.xda-developers.com/showthread.php?p=46117102
just picked up boost SGII (cant go wrong for $180).
In order to root should I odin SXTP_Agat_GB27-v0.3.0.tar ? I can't find any recovery kernels for GC01 on that site.
thanx for any help
use either 0.4.1 of this kernel or 0.5.0 the older versions have issues
Rwilco12's Android Repository - Downloads
scroll down the list on this page to get to them.
Yes, the GB27 one works fine (it is just the build number for the Sprint labeled version of the same ROM as GC01)
If you are thinking of trying Project X, just follow the instructions in the OP for it and you should do fine.
So I flashed the recovery kernel v 0.5.0
do I need to flash JB X2 format utility since I'm running stock rooted JB TW (i.e. is my storage already partitioned properly)?
also the op says to "install" EL26, whats the best way to do this? odin, one click or flash from recovery kernel v 0.5.0?
once again thanks for the help, I've been reading the forums but so many options and methods...it gets confusing. In the good old days (way back in 2010) we just booted into recovery and flashed a zip
Once you have downloaded everything to your phone (ROM etc). you can use your existing recovery to flash the zip of EL26 then reboot into recovery (option in the recovery menu) then proceed with the JB format, and ROM flash.
The Format also clears space so Yes, do it.
where can I get a safe EL26 recovery kernel? I googled and found a few different ones but there are warnings about emmc brick...
can I use E26_stockcwm.zip
found at
Recovery Kernels > GB > Chris41g > Stock CWM > ZIP on rwilco12's page ?
http://www.rwilco12.com/downloads.p...s/Recovery Kernels/GB/Chris41g/Stock CWM/ZIP/
Project X AOSP (4.3 Test Build)-[ROM][GB27] Project X v3.6 {Team Rejectz}(Updated 10/8/13)-Now with AOSP variants - Page 502 - xda-developers
Thanks for the help getting started. This is a great rom. Any way to lower the volume? It's great for morning alarm but ringtone and notification volume are 2 high even at lowest setting. Please and thank you
@buckwildpimp... that's looks good. You should add that to the variants Bil posted earlier!
