When it gona to release coz i am thinking to flash BT rom bcoz of good battery backupdont worry dear, I have solved all your problems and going to release JB V3 very soon which is working flawlessly on A75 without any bugs....![]()
may b today or tomorrow ..![]()
Great news...Waiting for the link...
i think there is problem with charging when mobile is switched off
Yes buddy
In the beginning I presumed hardware prob & wasted money for checkup.
More bigger problem is if your battery goes 100% down, it will fail to switch on & you have to charge externally.
There is a problem with kernel. This ROM has changed the kernel & it remains even if you install another ROM. I also tried installing stock baseband.zip file but failed.
Biggest problem is it fails to be detected by PC when switched off, so I failed to flash stock ROM by using flash tool.
Kindly suggest what to do.
any bugs .....?
Wait a sec, its real JB ?
Great, plz do link back the forum from where it was posted !
Hello,
This Rom is Fantastic!
i like to use it continue, if developer can help me with this issue.
since last year, when i got my touch screen replaced from service center,
i am unable to use any other [custom rom]. When i accept incoming calls
or if i do outgoing calls; screen goes black and until call ends, it stays black.
i think; original rom uses lighter sensor instead of Proximity sensor?
whereas custom rom uses proximity sensor!
i used Proximity sensor screen off app and found out, Proximity sensor not working but lighter sensor working fine.
Can you make some tweak to fix this issue
Please![]()
Are u rooted???
Yes Sir,
i am using this wonderful ROM:
[ROM] JustunBean - A Jelly Bean 4.1
Thank you very much for the response, i am glad
Originally Posted by hiraak View Post
bro can u fix the proximity sensor issue during call for sai's old ios rom....I tried so many but nothing happened ...
Quote: (by drdogautam)
put stock sensors.mt6573.so in /system\lib\hw folder n set permission rw-r-r-
so i did that, replaced sensors.mt6573.so from original stock (not worked)
replaced sensors.mt6573.so from ios rom... (not worked)
so, i deleted sensors.mt6573.so
sweet now; i can make call and end it. no more black screen. (red led is not blinking anymore at TOP)
only drawback is i can't use the feature which turns off the screen while talking.
until some developer find a fix for this, i can now use any custom rom meantime....![]()
