G
g60madman
Guest
Loaded the ROM up last night, no real issues so far.
Loving it!
Question, does the ROM have a overclockable kernal?
Yes Settings < CyanogenMod settings < Performance
Loving it!
Thanks for the quick reply. Now, my next question, I listen to music most of the day, is there a certain govenor I should use?
No issues. Using Skype over Wi-Fi all the time.Those who use skype, could you test and report.
Working or not.
Personally I don't ever mess with the cpu speeds. I have never under or over clocked the Triumph and never experienced problems. I stream pandora all day long by the way.
Not sure if I read that correctly but the change log says the latest one has less battery life?
Yeah I'm also curious to this. Is it less battery life or the GPS takes less battery life? I
Alright got it. Thanks must download rom nowG60 replied at the same time you typed the question.
To clear up the confusion, maybe G60 could change the log from:
08/09/2012
∙ Updated GPS it's faster and uses less battery life now
to:
08/09/2012
∙ Updated GPS it's faster and uses less battery power
Would you say that running underclocked almost all the time is a benefit battery-wise for you Chairshot? I've seen so many conflicting opinions about clock speed & battery life (underclock means less energy used by CPU vs. overclock means CPU processes done more quickly = less energy used). I guess I should just try it for grins sometime & see- it sure would be nice to put the MT in "long-play" mode if I know I was going to be using it & that it would be a long day with no chance to plug in.
One easy way to evaluate this is to download CPUSPY and run it over a couple of days of normal use. Then see what percentage of time your CPU is at low speeds versus the top speed. You will be surprised.
I'm a light user, for me, the CPU spends 1-2% if its time at the top speed, another 3-6% at all intermediate speeds except the bottom two. The rest of the time, it is in deep sleep or at the bottom 2 speed slots.
For me, there is really no point, what is important is the voltages at the lowest speed slots.
It may be different for you or other users that use their phone more, but you may be surprised.
Remember, your phone has to do an X amount of work, if the CPU is running slower, it will take longer to do that X amount versus a CPU that is running faster. So energy used is going to be pretty similar. There will be a difference, but not a whole lot.
I get over 24 hours of life when I dont use Navigation or am not flashing test builds all day and night but its hard to tell how much of a contributing factor it plays. What probably helps more is I only toggle data on when I need it and like I mentioned above for the most part only use Stock apps plus Maps, YouTube, Tapatalk, yellow pages, svox Victoria, SwiftKey, Play music and my bank app. I use the Kindle for just about everything else. Each device is for the most part completely opposite in how they are used. Why I keep things plain and simple with the Triumph the Kindle is all pimped out with JB, SPB shell, about 50 apps and widgets galore saving my Triumph from doing any heavy lifting outside of providing data for the Kindle when out and about but even that is a rarity.
, and also understand why (and possibly prevent/rectify) DSP Manager from crashing?First I want to say thanks for this rom and the work you've put into it. I really enjoy it. I am having one constant nagging problem that is keeping me from complete euphoria and would greatly appreciate any help anyone could provide me.
I keep my phone plugged into an FM transmitter in my car, and on the stock rom, whenever I would recieve an alert/message, the volume would dampen to half its normal loudness. The volume level wouldnt change, but the loudness seemed to drop off a good bit. To get the loudness back to normal, i would have to unplug the headphone plug and plug it back in.
I flashed this rom (20120808) today, and I am having an issue where on a fresh reboot everything seems to be fine, but the volume output isnt as loud as it seems it should be. After I tried to toy with the settings in DSP Manager (turned on/off compression), the dsp.manager process crashes and I am unable to access it again.
So i suppose this is two issues:
How can i get the volume to the highest level without distortion that android intended, and also understand why (and possibly prevent/rectify) DSP Manager from crashing?
