RolaAddict
hmm I wonder what is in the HDMI code that caused the camera to break.
Is there any way we can get this on the rom?
Are you sure you want that? It would require the phone to be awake to respond to the swype. That means no deepsleep. Mad battery drain. If you notice, in the video the guy has it plugged in.
Well, I would be willing to at least try it and see if there is a significant difference in battery life. Besides doesn't the rom already not deepsleep while wifi is on?
Well, yeah. That's when the WiFi is enables. I guess if you didn't mind the battery drain it could be a cool feature.
maybe when I get the new rig I can look into it, I need to see if the source code is available.
Edit: It may or may not work. On that phone the system has a way of keeping the capasitive buttons on without needing to keep the whole phone awake. I don't know if our architecture allows that.
deep sleeps fineAre you sure you want that? It would require the phone to be awake to respond to the swype. That means no deepsleep. Mad battery drain. If you notice, in the video the guy has it plugged in.
New version released. Camera is now fully functional!
One thing though...on the pre 8/6 builds temple run played fine and wouldn't freeze. And with the new 8/6 build temple run freezes. I think it has to do with the new GPU drivers.
there's a bug in inc/dec volumn when using poweramp..you might want to look at it when you hv time![]()
I second that request...
Awesome! Does this include main camera autofocus? Or should autofocus be working already? It hasn't worked for me since the g60style release that broke it, it just snaps to a really short focus distance and keeps it there when I try to take a photo with autofocus enabled, but stays set to a general distance focus (5ft to infinity) when I take a photo with it disabled.
I just flashed this over the 0806 version. I made sure to wipe both caches first though. Everything seems to be in working order. I did not want to do a full wipe and lose everything.
Quick question. I am dealing with a bout of Bells Palsy right now and I am having trouble with my left eye focusing so it's PITA to try and find how to eliminate the bubble background for the icon labels. Could someone point me in the right direction please? :hello:
