Maybe time for a new battery![]()
Battery is a 1 month old original Motorola. I'll test it again today and let you know how it goes.
usually it happens when you type wrong password for you Wi-Fi network.It keeps switching form "Obtaining IP..." to "disconnected", back to "authenticating" and Obtaining IP address". Sorry if this was posted ahead of me, I'll delete if it gets pointed out. Any suggestions?
The password is entered correctly.... tried "forgetting" network and reconnecting and re-entering password several times![]()
Wireless tethering disables when the screen turns off after about 3 minutes, I assume it doesn't prevent deep sleep like it should and deep sleep is turning off the wireless tether. I have to put the screen timeout really high instead which burns even more battery.
Otherwise everything works great, and nice job. Thanks.
Has anyone had problems with Skype on this latest build?
I can't get past the sign in stage (just says signing in with the circular progress bar spinning, and I eventually have to kill the app). I made sure I am using the right username and password, and also uninstalled and reinstalled the app. It won't get past the sign in.
I used to use Skype a lot on other CM7 variants. I am not sure if it is something with the app or this CM7 build. Let me know if your Skype is working or not.
This build is great and I really appreciate the work that has gone into it.
Hey g60 huge favor but could you put together a build that has working temple run? I believe it was the updated GPU drivers that broke it...anyways if you could do that that'd be awesome...thanks.
Could be a bad flash, maybe redownload the ROM and do a full wipe/dalvik. I have never had an issue connecting to any type of wireless network.
Have you tried rebooting your router, and also, does your router have the latest firmware update installed?... And since my laptop is working fine on wifi, looks like I have a hardware problem. ...
I have outstanding battery life.. even with wifi on all day![]()
Hey just wondering but is there any way to add the smoothass and/or lulzactive governors?
Hey has anyone had an issue with after wifi being connected for a bit some of the cmparts settings don't stick? Like on 3g its never happened but a couple times after being on wifi I would try to change my lockscreen style and it wouldn't change it!
When I get set up (hopefully) Thursday I plan on working on a few kernel mods. Now if I put in those governors you have to promise to report back how they work for you. (jk)
But I will definitely have time to test the governors out for you or any mods you release! You guys have done so much to make a beast out of this phone and I would like to help out in any way possible! (Since I'm not a dev or anything haha)Yaaay!But I will definitely have time to test the governors out for you or any mods you release! You guys have done so much to make a beast out of this phone and I would like to help out in any way possible! (Since I'm not a dev or anything haha)
Oh btw I don't know if you guys saw my older post maybe a few pages back about the "event4" wakelock that prevents deep sleep but I've done a little bit of research on it. I didn't find much about what it is exactly but it seems that the wakelock did occur in some of Whyzor's CM7 TG-Reloaded builds. Whyzor posted that he saw some "event" wakelocks occuring like "event4" and "event2." He released a kernel that seemed to have fixed these wakelocks and they can be seen in this post.
Maybe there's a way to implement his fixes into this rom?
