G
g60madman
Guest
Can you send me a logcat so I can look into this. I have yet to have a reboot since I installed 10
Is it possible to implement this: https://www.otaupdatecenter.pro/ into the newer ROMs? Seems like it would be a lot easier. Instead of flashing every new build, we could just update to the newer ROM just as if we were on stock Android. I'm still running the g60 style-final build cause of an incident I had with a bad nandroid flash. It kept saying the MD5 wasn't correct and everything I tried on a Google search wouldn't fix it so I had to start over with my whole set-up. Still thinking that I'm going to flash this build soon. Thanks for all the development and continued progress with the Triumph!!! You are keeping my phone alive and as current as it can get.
Yaaay!But I will definitely have time to test the governors out for you or any mods you release! You guys have done so much to make a beast out of this phone and I would like to help out in any way possible! (Since I'm not a dev or anything haha)
Oh btw I don't know if you guys saw my older post maybe a few pages back about the "event4" wakelock that prevents deep sleep but I've done a little bit of research on it. I didn't find much about what it is exactly but it seems that the wakelock did occur in some of Whyzor's CM7 TG-Reloaded builds. Whyzor posted that he saw some "event" wakelocks occuring like "event4" and "event2." He released a kernel that seemed to have fixed these wakelocks and they can be seen in this post.
Maybe there's a way to implement his fixes into this rom?
So for Gingerbread is this recommended over G60 Style? I've been running that for a while now but I'll use this if it's better in your opinion.
Can someone tell me how to make the 4 buttons at the bottom of the phone to stop flickering. Other thab that its an amazing rom.
I keep seeing this, but I don't have that problem. I wonder if it's flickering or just moving between levels of brightness quickly.
I have my brightness all the way up and my screen is bright but the buttons are dim and if you shake the phone a little you can tell its flickering. It has happened to me on all the cm7s.
I was at a friends cabin this past weekend and he started playing with my phone. I showed him some of the features and enhancements gained by rooting and using custom ROMs (specifically this ROM). I think I may have converted an iPhone 3 user to the Dark Side. As mentioned before, he tries to switch my phone to hotspot so he can use my 3G. He is starting to hate AT&T's $90 phone bill and no 3G at the cabin. I get my best 3G speeds up there for some reason (1.2 down and 600 up). Way better than in my living room at home.
Hey g60, first thanks to you and MTDEV for all the hard work you've done on these ROM's.
I got you a logcat. This was done using aLogCat, and was saved immediately after the phone booted back up, after a spontaneous reboot. Here ya go:
http://db.tt/KxrpL5HI
You may have seen me post this before, but I've been flashing ROM's to my friend's Triumph since he got it last y ear (I have a GNex on Verizon myself). I believe the first was the original CM7 by Tickerguy.
I think the next one we tried was TG Reloaded by Whyzor, then your g60 variant and also the Starship Triumph one, until we've been using this one (MTDEV 7.2) for the last few builds.
I believe it started when we put the phone on TG Reloaded, or when we first went to CM 7.2 beta. Either way, ever since then, he's been reboots, usually daily.
He continues to get them on the latest/last version of this ROM. I always flash clean - I wipe data/cache/dalvik etc first. Any apps are restored with Titanium. We have gotten rid of as many apps as possible trying to get rid of the reboots, and while he generally gets less reboots, they still happen. Any apps he has on his phone, I also have on mine and there is nothing strange (facebook, tapatalk, handcent, etc) - I think he has less than 20 user apps now, I have something like 150 on my Gnex, lol.
The phone otherwise operates just fine. Sometimes it locks up before a reboot, and reminds me memory management issues like I used to have on my Samsung Fascinate, which just didn't have enough RAM to cope.
Let me know what other info we can give you to squash these reboots. I'd put him on CM10 or CM11 or AOKP (what I run), as soon as I could, if only the camera worked in them![]()
Having a strange issue on this latest CM7 whereby Android is not detecting any of my external media on the SD card.
My MP3 podcasts do not show up in the default Music app (but they do in third-party apps) and the Gallery shows I have no pictures. None of the data is missing, it's still on the SD card and can be read just fine, but Android isn't "seeing" it correctly for some reason.
I have rebooted multiple times, tried a battery pull, wiped cache / Dalvik cache again in recovery, even installed an app to manually rescan media and so far nothing has worked...
Protonus,
How long has he been restoring apps with titanium? My suggestion would be to wipe/wipe dalvik and then redownload the ROM. Then install gapps and install one app at a time from the play store. I'm wondering if he is pulling in bad data with titanium. Give that a shot and let me know.
