Root [ROM] MTDEV-CM7 build 2013-03-03
how can I turn off button lighting? it seems to cause my back button to stop working. Am I the only one with this problem?
The back button not responding is a known problem. You can try rotating the phone or just waiting 5 seconds before you try pushing the button again as a temporary fix. I'm not sure if there is a permanent fix
The rotation tip will work and g60madman also gave a tip to flex the phone chassis and it will affect the buttons. While holding the bottom of the phone, press downward in the middle and upward on both sides and the failing button usually responds.
Always has been. But then again, I do to, on every phone I work on including my own. And I flash ROM's daily for people, sometimes a few times a day on my phone lol. And I've never had a problem like this, even with restoring green/yellow system items in Ti across different versions of Android...
And on my phone, that equates to restoring like 275 total elements with data, in Ti without a problem haha. It goes off without a hitch.
I can rebuild his Triumph manually next time we flash it I guess but, given how often I do this without problem on so many different phones, and how long he's had these issues with these CM7 rom's across dozens of flashes I don't know if I buy into it being Ti. Also, there have been many people on each of the aforementioned ROM's for the Triumph reporting the random reboots too, it isn't just his phone.
I've been suspecting it's a kernel issue for a while.
Did the logcat not show anything useful?
It's not necessarily Titanium Backup that is the problem, it's how the phone handles importing the app's system data from a different ROM as each ROM's system files can be arranged differently. This has been discussed several times for this phone and many other phones/dev's (example) have had the same problem with Titanium Backup. Just ask Mantera.
Whether that's what is causing your reboots... idk. I don't really know how to read a logcat yet.
Try and reset permissions in CWM if that doest work backup your SD and then format it and restore your data. Had to format my SD not to long ago due to multiple flashing of ROMs and everything was perfect afterwards
Fix Permissions didn't work, but the backup and reformat did.
Thanks! :smokingsomb:
I had the same issue, try rebooting the phone. Skype signed in for me after a reboot.
Yes. I found out it won't sign in for some reason If I have blue tooth enabled. but If I disable it and re enable it after it signs in.. it's fine. Also the youtube app doesn't work for me :(. Un installed it and re installed it but just crashes as you open it. And some flash videos just show up as a black screen. Other then these minor probs I like it. It's also my first time flashing a phone lol. And this rom and such seemed like the most stable out according to forum users.
For the youtube app go to settings < applications < manage applications < Choose you tube, and clear data and cache if possible. Give that a try.
I have been running some tests to address some of the concerns reported by users with this ROM and provide some assistance to our DEV team over on this thread. Here is what I have so far:
Soft-Key Flicker
I usually keep my brightness at ~20-25% to save battery and haven't really noticed any soft-key flicker. When I turned brightness all the way down I did notice some flickering of the buttons. When set to auto-brightness or turning brightness to 100% there seemed to be no noticeable flickering. I took "flickering" to mean like light bulb tweaking on crack. If the keys weren't lighting at all, then here is the next part.
Did some testing with Incredicontrol to see if maybe the voltages were to blame. Governor was set to "powersave" so the CPU would stay put at the min (245mhz), and the i/o was left at "sio". I decreased all outputs equally down about 200 mv before the system rebooted, did not notice any flicker on the way down. I repeated the test with the governor as "performance" to lock the CPU at the max (1024), again left the i/o as "sio" and took the voltages down 150mv before crash/reboot. Sure enough the soft-keys kept flashing on and off as the voltages were ratcheted down. So a dying battery could be the cause of some of the flicker if someone has a heavy overclock and brightness turned way up.
After the system reboot(s) I did notice that my soft-keys didn't light up right away, but I went into settings a toggled "auto brightness" on, then back off, and things were back to normal.
Screen Brightness:
I tried to find an app to test the lumen output of an android screen, but no such luck on the market. There is this, but it is for using your phone to test the brightness of a light, in a room for example, not the phone's screen itself. So the best I could do was take a few pictures with a digital camera in a dark room to compare the two. Quality control is crap and I wish I had some hard numbers to compare, but I guess its up to subjective user feel.
For the dark room test, my camera settings stayed the same (it is a Panasonic Lumix 14mp by the way), lights off in the room, flash off on the camera, and pics were taken from ~1foot above the phone and ~2feet above the phone with this app used to make the phone screen a "flashlight." I also included pics of my app drawer, same background (black) and launcher (Go Launcher EX) were used in the pics. The flashlight app automatically turns screen brightness to 100% and I manually set screen brightness to 100% for the app drawer pics.
MIUI Samples:
CM7.2 Samples:
Prior to the test I personally did not notice a difference in screen brightness between MIUI 2.4.20v3 and MTDEV-CM7.2. Though, as mentioned in the "Flicker Test" post I usually keep screen brightness turned pretty low anyway. After the test I would say that the results are inconclusive due to the lack of quantifiable measurements. MIUI may be a bit brighter, but for what its worth I'd say the screen brightness on MTDEV-CM7.2 is just fine as is.
Switching Recoveries
FYI if anyone is thinking of switching to TWRP (team win recovery project) from CWR, be sure that the first thing you do after installing is boot to recovery and make a new back up. You WILL NOT be able to access your CWR backups from TWRP and vice-versa. The same is also true if you are thinking of trying version of CWR newer than what you used to make your backups.
Volume
Increasing Volume in Cyanogenmod Settings: Menu > Settings > Cyanogenmod Settings > Sound > Increase "attenuation" levels and below that ("...if music is playing) Set each to "attenuated system setting"
Increasing Volume in PowerAmp: Open PowerAmp, menu, settings, audio, replay gain. Then under "Replay Gain" check "apply gain" or "prevent clipping" depending on if it is loud enough or too distorted. Under "Source", check track. Under the next two options select you desired increase.
For Distorted Sounds: Open App Drawer, open DSP Manager. Both "headset" and "bluetooth" have options to enable compression (at the top) and for loudness compensation if your using the DSP equalizer.
Estimated Battery Life
Interactive and iso left at default my est. bat. life was about 18 1/2 hours
SmartassV2 and cfq clocked to 61-1901mhz also gave me an estimated 18 1/2 hours
SmartassV2 and cfq clocked to 61-1901mhz and undervolted by 50mv produced an estimated 29 1/2 hours.
*Feel free to message me for further details and other results, but these were the best so far.
Undervolting
So far in my testing it has been best to take a stairstep approach and not just notch off a big chunk of power all at once. Use the smallest intervals and apply after each one to check for stability. It also appears that more active governors (interactive and smartassV2 for example) are less tolerant to undervolting. Heavy overclocking also tended to clash with undervolting, especially with fluctuating CPU speeds. I was stable undervolting all values by 50mV which yielded about 60% more battery life in my testing.
YouTube Flicker
As stated in the OP videos (YouTube included) flicker in portrait mode. Increasing screen brightness had no effect for me. Videos worked fine in landscape however.
Thunder.prop
dsmryder posted an updated thunderprop for this rom a few pages back. Which can be found here. I am not a gamer by any means, so I cannot attest to the full capacity of this tweak. But on the plus side I have not found any major issues after flashing ROM -> gapps -> thunderprop. Benchmarks with AnTuTu and 3G speeds with Open Signal were a bit lower and battery life was about the same. The main difference was button (soft and hard) sensitivity, which may be a good thing for gamers.
*Updated 8/18/12
To Do List: Skype issues?, B_kernel, theOC Kernel.
I have run into this with YouTube more than a few times when updating without a data wipe. Generally doing what g60 has said does the trick. I Wipe the App data in application settings and then from the settings menu will reboot into recovery and give both caches a wipe. Bring this up because I find doing all 3 before opening the app again works out best.
Yeah Youtube likes to act up a lot for me, also. Especially after that recent "update". Anyhow, the general rule of thumb is that when any app acts up, try clearing the data.
It turns out the issue with my media not displaying it was a bug in the latest version of ROM Manager which I had picked up from Play a couple of days earlier.
Comments and the update notes for the latest (fixed) version show that the previous version was creating hidden .nomedia files in some directories, causing exactly the problems with external media that I and others experienced.
The latest version of ROM Manager fixed this highly annoying bug.
I've downloaded every build of the 7.2 and I've been having a backup and restore problem...it would back it up as usual but when I switch to another ROM and try to go back to the backup and restore it it says mdpi mid match...I do factory resets and wipe all of the caches.. does anyone have a solution to this problem?????? Please reply it would be very useful..... and I might donate to the one who fizxes the issue..:-)
Sounds like you have either an SDcard problem of a clockwork recovery problem. What version of CWR are you using? And do you have another SDcard you can use to test with?
Did you switch recoveries? Say for instance you backed up a ROM with CWM and then switched to TWRP to restore? That can cause that problem I think.
Or maybe just try out TWRP (Team Win Recovery Project) and backup/restore with it and see if that works.
Soft-Key Flicker
Screen Brightness:
MIUI Samples:
CM7.2 Samples:
*Updated 8/15/12
In any of your testing, were you able to set any of your voltages to something below 800mV and have it stick? What I mean is I have set the clock rates below ~500MHz to 800mV and the phone would run just fine. Anything above that would cause a near instant reboot (don't set the "set on boot" option during testing), but if I set anything to 775 or less, nothing would happen.
CornfedChris is correct. If you switch to TWRP from CWR (for example) then you will not be able to access the CWM backups, but they will still be safe on your SD card. The reverse is also true. And likewise if the backups were made with an earlier version of CWR and you have a newer one installed. CWR 5.2.x is what is commonly suggested, I believe. I had problems with the newer CWR versions and TWRP is cool, but it irks me that I can't name my backups, but that's up to you.
I'm checking into it tonight. I'll update my other post when I get a few more results and PM you the specifics. I was running stable down to 850mv but i'm having issues while checking it again.
For the last week or so I'm dropping to20 or 30% in six hours with medium use. Normally I'm in the 50/60% range at that time.the battery stats have standby at 60% of the use, with 66% no signal which is my guess why. The thing is, I'm always in the same place every day, and I always have a signal when I pick up the phone, 3g and everything.No new apps. Wondering if it's a setting I don't know about, never had the issue with all the other CM 7's I've tried
If you just flashed, I would reflash after making a nandroid backup.
I have a bug for you guys, but I don't know if it's this rom (or all triumph roms) or gapps, or Googles music app or what. Let me explain.
I have tried nearly every Triumph rom and always seem to have problems with the phone deep sleeping reliably. I used this rom for a week, and it entered deep sleep the entire time. What i didn't do in that time was use the stock music app. I listen to a lot of podcasts, it's mostly what I use my phone for. During this time, I was on vacation and didn't listen to any, the phone worked great. Now, today, I started listening to a podcast. After listening to the podcast for maybe an hour, I stopped, put the phone down and left it. I came back an hour later and noticed a big battery drain (I've gotten pretty used to looking at my battery percent with this whole issue), not surprisingly, after using the stock music app for a bit, the phone no longer enters deep sleep (I check with cpu spy). I rebooted and it slept fine. Until I listened to some more podcasts, then it won't sleep. Any ideas?
Can you send me a logcat so I can look into this. I have yet to have a reboot since I installed 10
I got you a bunch more logcats... these are all after a spontaneous reboot happened. One of them though, he said the phone hardlocked and he had to pull battery.
Hopefully at least one of these helps you figure out what's wrong, or you can point out what app is causing these reboots...
http://dl.dropbox.com/u/47561278/alogcat.2012-08-15-22-11-00-0400.txt
http://dl.dropbox.com/u/47561278/alogcat.2012-08-16-07-53-20-0400.txt
http://dl.dropbox.com/u/47561278/alogcat.2012-08-16-20-11-31-0400.txt
http://dl.dropbox.com/u/47561278/alogcat.2012-08-16-20-12-10-0400.txt
http://dl.dropbox.com/u/47561278/alogcat.2012-08-17-08-53-29-0400.txt
same here!
Are you sure it is a software issue? Have you at least tried cleaning the battery contacts to make sure it's not an issue with a dirty electrical connection? Do the reboots also occur when running with external power connected?
Back to the sharp rom!
Everything is broken in this CM7 build. GPS takes about 10 minutes to lock, it absolutely eats battery, doesn't charge right, the tethering dies after a minute or two, the music problem still exists.
Thanks for the hard work regardless!
I think you can probably deduce from all of the happy comments that the problems you are experiencing aren't specific to the rom but to you.
Are you sure you followed all the install directions properly?
Prontos,
I don't have the time to look at these right now. However I can tell you how read them.
D/ - Debug
I/ - Information
E/ - Error
W/ - Warning
V/ - Verbose
You will want to find all the E/ and find out what is causing the problems. If you have done all you said and actually reinstalled each app from the play store and not using titanium I would load back the stock ROM and see if the same problems are happening. If so then its hardware.
Hello G60madman,
Thanks for this good ROM and all the improvements you made for this phone.
In my case: battery life and GPS speed are very good and it charge right.
But are you sure you have fixed the problem of the volume of the headset?
I still have the problem with the message notification which decreases the maximum volume of the headset. I followed the installation procedure, did wipe data/FactoryReset wipe both /cache and /dalvik and even sometimes format /data and /system and also fixing permissions.
The problem appear each time I reboot my phone or after installing a new Rom and what ever ROM version I am using ( I am using actually your latest build 20120810 with kernel 2.6.32.9-perfG60madman@mtdev#1) the maximun headset volume stay low ( pausing the music for 4 seconds doesn
