Root [ROM] MTDEV-CM7 build 2013-03-03
0923 is smooth as butter, GPS is really fast but I'm having problems receiving calls. It only rings if I'm in a call, otherwise I don't get the call at all, it goes to voice mail. I restored the stock nandroid backup and i'm receiving all calls so I know it's not a hardware problem. Any ideas?
I was hoping with today's update of Temple Run that it would become more playable, but on the rare times that it actually begins a game without rebooting, it still reboots every time I die.
It also reboots whenever I even just try to go into the Options screen.
Oh well.
flashed cm7 and gapps. when i log into gapps and text message i get error message.
did factory reset, cache, and dalvik. Any help?
Everything else is running smoothly
ok 1 asks to add existing account
2 I log in to my existing account
3.than asks me to back my apps etc
4. turned on wifi and i have a good 3g signal. The browser is working. I hit next
5. than it logs into google play and it say server error with a retry button.
i get the same thing when i try to log into my contacts.
_
Tried reflashing cannot get playstore past server error
And i cant log into my contacts. Also get server error.
When wifi is connected with good connection, it doesnt get the
Server error message. It just times out and doesnt log the whole way into
The play store.
jmulvay, does your 3g icon change color, signifying that you are, indeed logged in to Google?
And are you sure you didn't flash Ics gapps instead of gb?
Just as soon as I say no widow issues I start having them! Still having the issue where if you reboot with wifi on it keeps turning itself on over and over again until you reboot again, and it will connect to wifi networks but most of the time the icon stays gray and the internet wont work or it will turn green but the internet still wont work. It seems to be a DNS issue. Its done this on several networks including my home!
And has anyone had an issue where while in call it will mute your call then when you try to turn the screen on to unmute it, it drops the call? Its done this to me on just about every cm build. Not sure what's causing it!
Just thought I'd throw in some bug reports here!!
I personally haven't seen the call mute issue, but that is the exact wifi issue that I had after not doing a full wipe before flashing a new build.
thangfish. I logged into google through
the the google browser. I can see at the bottom
It says i'm logged in.
I used the gapps thats linked at the top of this thread
in the cm7 install directions.
Aye i used the ginger bread gapps
I have never owned a Motorola Triumph and i have been following your ROMs for a while. I am just amazed how amazing the developers in this forum are.
We have a great group of users that support us even when we make mistakes like when I killed gps on CM9 :p. It' makes it easier to keep trying to deliver a better ROM each and every time as we are backed by everyone here! May not be the best phone on the planet, just the best people using it :)
Ok for that, but does your 3g icon on the notification bar stay grey, our does it change to green (or blue, or whatever color your theme is). If it stays grey, your device hasn't successfully logged in to Google. Sounds like that may new the problem... of so, figuring out why will be the solution.
Ok you were right, i didnt wait long enough for the
grey 3g n bars to turn blue.
When they did it worked. Thank u.
This rom is awsome
Thanks to who ever re added live wall papers.
All apps seem to be working. Love the car app
Anobody else experiencing this issue with the 0923 build? Should I try to reflash it or?
As far as I know the only issue is the video recording for camcorder, and some videos on youtube seem to be having issues with weird overlay. Chairshot is aware of the problem and working on it.
I'll flash it tonight and see if i have any video issues others are reporting ... at work till 12a
It may have been the always use proximity sensor and keep screen on longer options. I have turned those off and I'm gonna se if it still does it!
But I did a full wipe on this install because I was on the stock rom before!
It's a program to bridge phones using a backdoor in androids debug adb to p2p pawn. I correct myself terminal opens it's the file that's not opening. I think I found the problem..Love the work your doing btw, you've made this phone better than I hoped it could be.
thank you Chairshot215 I've been lurking for weeks and am extremely impressed with you guys and all the hardwork that you have done making this phone awesome my husband who pays $120+ to have an iphone on verizon [that he only even uses to like check espn] he always made fun of me and my phone/vm but i'm like oh hey can your phone do this no? ohh that suckssss and i'm only paying $25 but i got 2 lil babies and one of them is starting to crawl this week and it would probably freak people out if i posted my Blue Avatar daughter crawling across the room lol
keep up the hard work and i hope to donate something to you guys soon thanks again!
Due to issues with the Camcorder we have reverted the build, however there shouldn't be any problems with bootloops. Chairshot is still working on the flicker. Also I had to post a link using media fire so it's not on our download site as of right now.
MTDEV-CM7-20120926.zip
