I saw no improvement, either. But I did start having random reboots, so I removed the Disable CPU Rendering mod.
If you manually edited egl.cfg, don't forget you have to put permissions back to rwrr.
Possible, but I saw no change either.![]()
This old man appreciates your reply - sorry to cause even a small stink - this is such a great ROM and i appreciate what everyone is doing with it. - everyone keep up the great work - I am learning as I read and try it all out.
Just to post some updates I'm on the 23 build and I'm still gavng the call mute then drop issue and my wifi is really messed up. If it will turn on, it will connect but can't ever resolve with the DNS server so no internet connection and sometimes it will turn on then right back off.
I am also on the 23 build and I haven't experienced any of the issues you listed. But I sometimes wonder if the "wipe data/factory reset" function works the way it should (I am on CWM v5.0.2.6). I know that I have "wipe data/factory reset" and cleared cache then install a new rom and find that some of my settings have carried over from my previous flash.
I don't have any answers... just wondering if others have had lingering data? And if so could it explain the problems you are seeing?
It seems that 5.0.2.6 carries over data, 5.0.2.7 is the one I have had the least issues with, 5.5.0.4 and up seem to work fine but only make backups as ext4 so with some ROMs you have to change the names to ext3 and the names of the files in the md5 also, to get it to work properly. Hope this explains things for you guys.I wonder if you're not correct on that... I've seen the same thing a time or two. No explanation.
Since updating to 9/26, I have been experiencing slow 3g speeds. Even with 3/4 bars, I rarely get over 500kbs.
When I was one 9/21, speeds were between 1 - 2 mbs.
Anything to check, or did the PRL change between those versions?
Is there a preferred PRL to use?Your prl file can not be changed by flashing a ROM. It's a separate process.
This 9/26 is sweet, overclocking settings, what would you suggest?, gov?
I did a Power Down, pulled the battery for a few, and speeds seem to be back to normal.Since updating to 9/26, I have been experiencing slow 3g speeds.
At this point, is there any benefit to flashing this (“Vastly improve GPS for all ROMs”over this ROM? Has it or something better been incorporated into this ROM by now?
Basicly, if it came from a member of the MTDEV team then, no. As Chairshot215 works his way through the device files and configurations he is going to find stuff that will work through other ROMs.
