thangfish
Android Expert
I'm just getting started in programming, but if I can find an example of a manual iso setting, then I can probably bring it in.
I went looking for camera mod code, and did find some, but for a different device of course.
I found and installed a modded camera apk, which worked as far as taking pictures, but the iso settings didn't work.
I also remembered that the HDR Pro camera app (kick ass camera app, with the right phone!) doesn't function properly on the Triumph either.
Thinking that our hardware may not support this, I started looking for a way to test it.
I then ran across an app on the playstore called Camera FV-5 (lite). Nice camera app, btw.
Using this, I was able to manually set ISO, but exposure compensation didn't work.
That is what makes HDR Pro not work also, I think.I guess our hardware just ain't the best.
. I'll push the power button, the screen will turn off but imediatly turns back on, or when i click the power button the shut down options randomly comes up. Any ideas? Not trying to reflash -_-
