What kernel does this work with and what kernel does it come with?
I just sent $20 dollars to help keep this moving.
Thanks dsmryder. Reflash did the trick for the vibrate only incoming calls issue. Not a problem since, except for random shutdown....say weekly. 0926 build related or something with the increased capacity e-bay purchased battery? Pulling the battery is the only way the phone will boot when this happens.
Anyone down for some beta testing??
Trying to get as much feedback as possible but put this build together over the weekend. For the most part added a bunch of permissions I found why unpacking the boot.images from Bsidz experiment Nandroids including a few media related. Also have replaced the init.qcomm scripts with those used in Sharp 2.3.5 inside etc and removed a few proprietary files that have been added in from Triumph Stock I have only otherwise seen in Froyo Roms among our device family tree. Anyhow have been testing now for a few days along with others but have limited access to Bluetooth devices so would feel more comfortable with more feedback in that area or in general before officially pushing or adding.
FOR Testing Only
MTDEV-CM7-20121006.zip
Cool, I just downloaded the CM7 code and was gonna start from scratch and see what I could do, the MTDEV team CM7 source is soooo different than the CM7 code I had on my HD from like 4 months ago. We should be able to use most of the qualcomm stuff from the zues device file setup, I think G60 was talking about it sometime ago. I wanted to use the ICS kernel from the Xperia Play, and camera drivers, to see if we could get something going on the ICS camera issue, but at that point I had never looked at kernel source before. I have high hopes for getting the Sharp 2.3.5 kernel on our phone, I just need some more time with the kernel. I have found the baseband issues in all of the X6 kernels I have source for, Mi410_v3.18D_kernel_source_2.6.32.9 and both tj_styles kernels. Also after flashing some nb0s again, I found that bluetooth worked fine with an nb0 flash but just the kernel and ROM from the X6 variants bluetooth doesn't work. It has to be a firmware mismatch in the kernel, that is one issue in the 2.6.35 kernel. Hopefully we can get a rock solid system that every single thing works (up to hardware limitations of course) above Froyo on our device soon.Anyone down for some beta testing??
FOR Testing Only
[snip]
FOR Testing Only
Flashed ROM last night & had no issues with Bluetooth connecting & using my RF-MAB2 headphones as well as monster iclarity speakerphone.
On another note, while still on mtdev 7.2 9/21 build earlier yesterday , I was unable to download opera mobile update via play store (had the 'not compatible with this version...' message). However, had no problem doing so with this ROM.
Overall ROM is snappy works well for me.
Just want to let everyone know I had been having wifi issues where it would connect to a network but would never obtain the ip address and therefore I never had internet, and I read a post somewhere saying that on another phone the video.accelerate.hw build.prop line had been causing wifi issues, so I commented it out and wifi will connect and so far I haven't had any issues with wifi staying on even when trying to turn off after a reboot with wifi on. Not sure how this is correlated but if I were you all I would remove this line anyways as we don't know if it really even helps. Just thought I'd put that out there!
Were you you useing a thunderprop of some sort?
Hey, I hadn't even noticed that tablet tweaks has been missing! Damn.
Thats funny because I don't think the MTDEV CM7 has ever had them. Thought the menu looked nice and sleek without them or the system update settings that FC when selected so removed them from the menu. Also for the same reason you had mentioned, took 3 or 4 month for someone to have noticed. Can still be accessed if desired by selecting a short-cut by pressing anywhere on the home screen.
