So, I've been playing around with CM7 latest release today. It is more solid feel than previous releases. So much smoother and scrolling feels like stock ROM.
Here are some bugs I found:
-Gallery causes reboot on certain files, especially *.png format, when I tried to zoom in and move around.
-Screen Locker doesn't change right away unless reboot the system.
-Auto brightness seems very low on default.
-Volume is a bit lower than stock but doesn't cause it to go lower after notification sound. This is only noticeable when I hook up the phone to the car stereo.
-Video recording doesn't record the voice when earphone is plugged in. For some reason, I don't have the clicking noise. I've tested in many position to cause auto focus.
EDIT: Just encountered a weird bug. Whenever I press the browser address bar, when the keyboard comes out, browser disappear. If I press "back", the browser comes back but the screen gets locked.
Other than that, it is the best release so far and I'm sure the next one will be better. Oh. I've tested wifi with both visible and invisible access points. Both works well and stable connection for me.
I have some suggestion I thought might be a bit useful or maybe silly.
-Video flicker in portrait mode. So, why not lock the video playback to landscape mode only like stock 2.2 ROM. That will save you guys a lot of time.
-Since this is not the final version yet, you should add formatting system/data/cache partitions in updater-script to make it fresh install. Fresh install seems to eliminate some bugs and ROM is very stable.
-If that can't be done, this is just a fun idea. Why not reroute the IP of Update option in Settings to MTDEV file upload server and release updates from there to auto download the update.zip? That would keep us updated and MTDEV will rule over Motorola.
Anyways, I'll keep messing with the ROM to see if I can find anymore bugs or improvements.
