Root [ROM] MTDEV-CM7 build 2013-03-03
Hey Chairshot, can you post MD5?
I boot looped. May need a fresh download.
Thanks.
Sorry I had forgot to change the update script to remove the extra cache wipe like I have been doing for the last few builds. Going to take a sec as I am currently hospitalized. If you open the ROM with 7zip you can swap it out with the script in the last build. Pretty sure its under meta-data/Google/updater-script. Otherwise will post a new build whenever I am released, sorry about that.
I was just wondering if anyone has had an issue with music, notification, and alarm sound under settings menu constantly reseting back to default after leaving menu and going back in? Was also wondering if any is experiencing the custom vibration setting not changing anything (stuck on "2" vibrations)?
There was an issue where the WiFi would prevent the settings from being changed when it was on. Is you wifi on?
If you posted your changes to github, I can redo the triumph-from-ota (Something like that) script builder and post it up for you.
Sorry to hear you're in the hospital.
saves settings, not custom vibration tho. And I have been running into issues with my playstore too. tried everything, can't delete account without wiping data tho.
keeps getting popup error box saying "Sorry - the application Google Play Store (process com.android.vending) has stopped unexpectedly. Please try again. [force close / report]"
The newest version and the ICE10 theme together equal BLISS! I'm in love, thanks for all the hard work!
I love CM9, it's what I have been using for a while now, just missed the camera.
I just did a full wipe and clean install last night of the 10/15 build and its running much better. I had it installed over a heavily modified mtdev build without a wipe and was having some issues so I decided to do a full wipe install, of course I still tweaked everything a bit, then restored my user apps with titanium and its running like a champ!!
Also for those of you running compcache I wouldn't. It seems to be smoother without. If you do use it I would set the disksize to 10%. It seems like its bogging everything down having to compress and decompress men pages. I think we need to clean our zram code up in the kernel and maybe use a different compression algorithm for it to be effective!
But this build is by far the best and I haven't ran into any serious issues yet! Anyone tested wifi deep sleep since he updated to the sharp wifi module?
Yeah I have mine set to never deep sleep with wifi on. You can't set it in advanced wifi settings but you can change to where it sleeps with screen off and even on the stock Tom if you set it to this and it slept to long it would do a "sleep of death" where it wouldn't wake up. That's why they put the wake locks on wifi.
If I remember correctly, the wake lock is in the kernel. It was nessesary to deal with a lock up condition when the phone went to sleep and the wifi was on.
Yeah actually that's right! I know the sharp wifi module seems to work better and load faster than the stock triumph wifi module!
You know? g60 gave us the link for the program that can check what calls a library likes. I wonder if we could use that to fix the need for the wake lock?
And I still don't know what I'm looking at with that thing.
This ROM is AWESOME! I had to reload the stock ROM to call customer service and my god, what a difference!!! Thank you guys for the fantastic work!
I noticed WiFi doesn't always reconnect when the phone wakes up on the 10/15 build. I have to turn it off and then on to connect. No big deal, just figured I'd mention it.
And I have one small request: can you please update the Droid font to the latest version found here:
https://github.com/android/platform_frameworks_base/commit/6a19759c0fae744e80c032ca3c23932e73e6d9d9
It contains some characters that the older version does not display.
Thank you!
Thank you!
I think I'll look into it tonight.
How do I change it to never go to deep sleep? I can't find it in the settings, can you steer me in the right direction?
Thanks
-Excalipoor
never deep sleeping imo is not a good idea but you can leave your WiFi or Bluetooth on and it won't deep sleep, don't forget to put your battery to bed.
1015 build
i started having problems after using Bluetooth, idk if it's related or not but the problems didn't start till then. one thing i was getting before using Bluetooth on 1015 was touchscreen lag, i thought this was a keyboard update issue but after going back on rom ver and keeping the updated kb, the issue is gone. while using the newest version of the rom after using Bluetooth and rebooting the phone the WiFi was screwed. i haven't looked at the code so i can't say if or how one effects the other but with the mixed reviews it's worth looking into.
