Excalipoor
The Wi-Fi still stops working when plugged in
I gotta know. Why would you want the phone to not deep sleep?
Also, if it's plugged in it won't deep sleep.
Serious Wi-Fi problem.
I was using CM7 until I got sick of the Wi-Fi issues. So I upgraded to CM9 thinking that it would fix it.
Here's the problem: After screen gets dark for 10-20 minutes, I wake my phone and Wi-Fi doesn't work (icon is white instead of blue).
Here's what I did: I did factory reset, clear data, clear cashe, clear danvisk. Installed new rom and gaps (reboted 4 times over time). Changed Wi-Fi sleep policy to never (checked it several times) and connected to Wi-Fi. After pressing sleep button and waiting 10-20 minutes Wi-Fi stops working.
Exact same problem as CM7.
If you guys could help it would be greatly appreciated.
Thanks
-Excalipoor
Or maybe this night![]()
Quick question. i switched to this rom from miui. and now most of my music sounds like
crap. The songs make my speakers pop and they have no bass. Is there any settings i
change to fix this. everything i try to change doesn't seem to work.
thanks
Ok just checked Mediafire and it looks like we have 42 people who have downloaded the last test build. Has anyone come across anything off compared to the 10/15 build?
Have also been curious if there has been any change in thangfish's voice dialler.
It's funny. I had 25 downloads of my tester ROM and no reports back either.
Hopefully thats a good thing, lol.
Does anyone's phone blacklist not work or has it ever worked?
I'll tell you the truth, I've never used it. Are you using the built-in phone app. It should be linked to that.
If it's a really useful feature for you, I can look into it. Keep in mind I am trying to do other things, though, but this might be a useful break for me. (if you can call it that)
Has anyone gotten Google Voice to work with this ROM? I have it set to "Ask every time I make a call" but I never get any prompts. I've tried "Use Google Voice to make all calls" also without any effect.
More on the 10.21 test ROM...
I don't use wifi often, but today I had the same problem from 10.15: wifi kept trying, but wouldn't connect, so I rebooted and connected immediately, but camera quit. I notice because I use front camera for face unlock.
Edit: both cameras btw.
Edit 2: after another reboot I have wifi, back camera, but still no front camera
Bump that, you aren't even using my tester![]()
