The newest version and the ICE10 theme together equal BLISS! I'm in love, thanks for all the hard work!
I love CM9, it's what I have been using for a while now, just missed the camera.
Hey is the CM9 boot animation able to work on this CM7?
I've got a bluetooth problem and would like to get your thoughts and suggestions on what to do. First I only use BT for a car phone. No other audio / music functions. What happens is that after pairing and connecting the phone to the car, answering any incoming call does not use either the car radio -or- the phone speaker forcing me to hang up and call the person back. Both the outside caller and the car cannot hear anyone talking and have to hang up. Outgoing calls always work normally. Incoming calls, no sound either end. After disconnecting, unpairing, repairing, same issue. Here is what I have found: If, after receiving the call you toggle from BT (car speaker) to phone speaker, and then BACK to BT, everything works. Both callers can hear each other and the call comes in over the car radio speakers. Another thing I stumbled on was that if instead of answering the call with the button on the car radio, I answer the call on the phone instead, everything works too. So, to summarize incoming calls= no audio on either end. Outgoing calls work perfectly. On incoming calls, toggle speaker bt->phone->bt and it will work normally. I used MIUI for the last year and switched recently to CM7. BT has always worked perfectly on MIUI. I have wiped and gone back to MIUI (bt works normally), fully wiped and re-installed a clean copy of MTDEV 1015, and before restoring anything (virgin rom) tested the BT again with the same results. If this is a ROM issue, then surely others are having the same problem? I love the ROM and will continue to put up with the annoyance, but would love to get it fixed. Everything else seems to work perfectly. Any ideas?
Yes, used the original CM9 Galaxy Nexus animation in the Starship Rom and took it directly from the CM9 zip. Just need to swap it out in system/media.
Yeah at some point Whyzor fixed the CPU pegged at max frequency with both wifi & Bluetooth running at the same time by removing a bunch of Bluetooth permissions. I have heard that at some point in the past BT diallers that had worked started having issues and I am pretty sure this is the reason why. I have been trying to get the BT Diallers working again and restored the permissions in the 10/21 test build without bringing back the issue if you would be interested in testing it with your BT dialler as so far there is only one other tester using such a dialler and could use more feedback as I don't have one myself. There are a bunch of more comments on the subject on page 20.
10/21 test build
MTDEV-CM7-20121021-test-B.zip
B_randon14 said:Yeah its the btwlancoex binary which I beloved stands foe Bluetooth wlan coexist. Don't know much more about it though!
Thanks Chairshot, I will test this and report back today. Trying to understand why all BT outbound calls (hands free, using the address book in the car radio) work fine, but inbound calls have no audio on either end. Its just weird. There is a kludge as mentioned above, but accepting the call from the phone kinda defeats the whole hands free (safety) aspect of a BT connected phone. THANK YOU.
Hi B_randon, I thought we had the BT/wlan coexistence issue on Isaac's MIUI, but the BT worked with it np? btw....lovin' that 6.0.1.5 CWM.
Seems that even though I manually turn the wifi off when I leave my house, somehow the setting does not stick and wifi comes on by itself and preventing the phone to go in deep sleep mode. I was able to replicate this issue 4 times in the last 2 hours. Anybody else having this issue? Any idea what can be done to fix it?
Loving the ROM, but I have a question. Every ROM I've tried does not have a working voice recognition for inputting text (text messages, emails, etc). This is the only aspect of the stock rom that I'm missing. Is there a reason that this feature isn't in any of the roms? Even when I download a keyboard with the microphone on it, it never actually gets to taking in a voice input.
You may just need to download the Google Voice Search app from the Playstore as it was included in Stock but must be downloaded from the Market for CM7 as it is a Google App and can not be included for legal reasons.
I know that this is probably a stupid question but, can this version of cm7 support a backup from cm7 g60 style final? What i mean by this is if i made a backup and then cleared everything and flashed this could i restore the data from advanced restore from a g60 style backup?
Try a reinstall, because it's working great here... No issues at all
Can't tell you how many I've used it to look at themes.
Also,.just so you know, I'm not having the incoming BT audio issue either.
Did you do a clean install?
Since this ROM is still under development; how should one flash the future version upgrades?
For example you have version MTDEV #1 20121015 flashed and a future upgrade to this ROM becomes available.
If you flash the latest ROM version and then restore from a nandroid backup won't it overwrite the modifications made to the system files?
In effect, don't you have to flash the latest version and then restore you apps from the Play Store and then use Titanium Backup to restore the data to the apps?
I went from G60 to MTDEV #1 (yesterday); very happy with the tweaks. I'll continue to follow you CM 9 progress; looking forward to making that jump.
Mark
