dsmryder
Android Expert
No way! OK, so I think I follow you. I had an Optimus V before this phone, so its easier then the OV?
Way easier!
In reality our phone comes pre rooted. You just need to know how to access it.
Way easier!
Thank you so much.... this is awesome. Now quick question....how many times faster is this phone over my old OV that I had overclocked to like 806mhz?
I'll let you figure that one out on your own. There are way too many factors that come into play to properly answer that question.
But its safe to say yes right lol, do we have more RAM?
I think the two phone have the same amount of RAM. Which means the MT has less because of a bigger RAMdisk. But, the MT is faster in every way except GPS. Then you have to have a custom ROM that makes our phone better, then it should be faster. I don't know. No one has made a test and reported it yet.
I was going to grab the new HTC Evo V but snagged this for only $139.99![]()
What version of CWM am I supposed to use to flash this rom? And also for the Google Apps, do I just flash those after the ROM gets done flashing?
I have noticed two bugs after the recent update..
one is the SMS aren't automatically spiting after 160 char like it should. and there are no settings to enable it. only work around that I know of right now is to force it to send as an MMS after 1 text length
second issues I've had with the most recent update is cellular connection drops, I will be in the same area with out moving where I was getting service and all the sundden my phone will have an X on the signal with the R for roaming.. all I have to do is restart and it comes right back until it has the issue again but it won't fix without a restart which leads me to believe its a software issue.
other than that this rom is by far the best thanks for all the work. can't wait for the Camera!! hehe
I've been using the update since it was posted (the latest) and my battery life has changed phenomenally for the better! Not sure if that was on purpose, but it still made a huge impact, thanks so much for the update!
Oh, you ran the car door mod? I thought that one was a dead mod.
Airplane mode should take care of anything that is fixed with a reboot, signal wise.I see an option right there. Does yours have that?![]()
I know that chairshot was working on some libraries specificly for better life. Maybe he can chime in on that.
no the stock sms app in this rom does not have a split sms option right now. the airplane mode doesn't seam to fix my signal issues, only a reboot.
Edit: Airplane mode does seam to fix my signal issues now, hopefully the next updates fixes the signal issues..
Thanks,
Jason
Holy crap this is amazing. Makes my triumph feel like a newer phoneHow close are you to the camera? Thanks for all the work on it!
Keep in mind, I have not been using the phone like I normally would during the week for these recently recorded stats. Still, my MT has never seen battery life like this, especially with GPS enabled and wifi on.
Having GPS enabled should not impact battery life unless you're actually running an application that turns on the GPS receiver (Navigation, Endomondo, etc). Basically, if you don't see the GPS icon active in the task tray it's not using battery power.
Oh because I always thought that by it being activated it was using battery because it stays locked on a satellite.
Great work dev's!
Just awaiting the camera fix for this, I have money to donate.
Stupid question but whats the response from Motorola on getting the required files/documentation for the camera?
