christiansoto
I think you are doing a great job. I just need to wait until the camera is fixed. I have to make online deposits using the camera for both Bank of America and Chase banks.
Wifi not working !!!!!!
Having GPS enabled should not impact battery life unless you're actually running an application that turns on the GPS receiver (Navigation, Endomondo, etc). Basically, if you don't see the GPS icon active in the task tray it's not using battery power.
I hate to keep popping in here about losing root (really do, you guys are busy with plenty more than JUST root), but I can't figure out what on earth is causing it! I've upgraded, I've uninstalled updates, I've tried 'sudo' via terminal emulator for the root commands and it says 'not found'. I'm going to try a full on root method and see if it works.
Let me add that it seems to lose it over time I think. Sometimes Titanium Backup works just fun, others it can't get access. It's also causing a few of my Tasker profiles to fail to run. I'm trying Gingerbreak, will see if it helps.
you have to use ES File Explorer or Rom toolbox to change root app names and rename SuperUser.apk to SU.apk in the Root/System/Apps folder... changing the name DOESNT unroot your deviceHow did you get the twc app to work? I get the rooted device error.
really?
Yes, enabling GPS doesn't actually turn the GPS on full time - it just allows other programs to turn the GPS on and off as needed. Disabling GPS just stops programs from being able to turn GPS on. If you don't see the GPS icon in the notification tray then GPS is not on.
Any updates for anybody trying to get Google Now? I've tried several ways. Most end up with it installing from a zip and I access it but before I could really do anything it force closes.
Which way did you go about doing it? I think you may be right about not having enough space. If thats the issue how would i make more space? What would i delete?Probably means you flashed it but didn't make enough room for it first. A few pages back someone posted a link that will give you all the information you need. Been running it flawlessly for a while now![]()
Couple more issues I found:
Wifi doesn't auto-connect
Data spends more time as 1x vs 3G. Dunno if this is something specific to this build, however it seems to have been happening since flashing to this from CM7
Thanks for all the hard work!!!!
I Love this Rom But only one thing is just killing me...How on earth do i change the carrier name! The Old Zip was made for the other CM9 Rom..n i have tryed flashing that carrier changer zip file but it does not work with this CM9...SO Can Anyone help me ?
I'm doing some testing on something, so I can't check. I thought there was an option built-in in the CM settings menu. If so, could you post back?
