daseinredux
Member
I rebooted into recovery, wiped data/cache/dalvik and flashed zip again. I don't remember if I restarted using the rom.
It does sound like the error was on my side somewhere.. For now I have CM7 running almost perfect. A couple months down the road I will likely try CM9 again and hope for the best. Thanks for your help.
It seems like many users who try to flash from cm7 have problems. I wonder if CWM is always properly updating the boot image during the flash of the new rom. What version of CWM are you using? I know that some versions have had some bugs in it. Maybe next time to try to flash CM9, you can check what kernel is installed in "About Phone."
