I'm having the same issue about the browser but I think its cm9 it self.....since I have a cm10 on my tablet & has the same issue....... also, some of my apps force close.......
Another thing, the Wi-Fi turns on by itself![]()
What other apps do you have installed? I don't think I have heard of that yet. I wonder if it's like the settings not sticking in CM7?
To be clear, do you mean that the wifi radio is set to OFF and then it just switches to ON? I just want to make sure that you are aware that disconnecting from a wifi hotspot or access point does not actualy turn off the wifi radio. Verify that your wifi radio is actually set to OFF. If you are disconnected and wifi is still ON, depending on your settings, it might reconnect later. This could appear as if wifi was turned on, but it was never turned off.
If you have manually set wifi to OFF and this still happens, did you flash GAPPS when you first installed this ROM?
Restoring some google apps and data can also interfere with wifi functions.
I rebooted my phone and it stopped doing that
The wifi was always off but when I woke up my phone I noticed it was on it kept doing that for a while but I shut down the phone and turned it back on and now its normal lol
Is there a mod that will change the lockscreen? I've looked all over xda and found nothing that would work on our phone.
Go locker, Holo Locker, and Magic Lockscreen. All in the play store.
Hey guys, have you experienced random reboots? For some reason my phone keeps randomly restarting. My battery life has also gone down a ton. Not sure if it's due to the random reboots. Any help would be greatly appreciated.
Thanks
I know that. I mean an apk or flashable zip.
Thanks
Hey is anyone else having issues loading google latitude and having it freeze up you phone. I cannot get it to work.
Last time i had random reboots it was from using a task or app killer. If you are running one, these are not helpful - particularly with this OS.
I have a working backup of this rom from october.
I just wiped data/cache/delvik, installed zip of 11-13 build. Installed gapps for ICS immediately after without booting. I start up into system and don't get the play store.. I repeated this process a few times. I verified correct 11/13 file and correct gapps file.. Still no play store.
This seams pretty strange to me. I have no idea what could cause it.. But I have given up and I'm back on CM7 I guess.
I could do without the camera if CM9 runs more reliably than CM7.
I have flashed all the recent builds and not had a problem with accessing the play store.
Did you have Android Market in apps instead of Play? If so, it should update to play when it detects you have a rom that is 2.2 or higher.
You said that you repeated "this process." Do you mean that you flashed cm9 and gapps several times? After you started up the phone and went through the initial startup, did you reboot the phone and check for play again? Or did you just go immediately back into recovery and reflash the rom and gapps again? Some users have noticed that they needed to reboot the phone after starting it up initially to clear up some issues.
