Maybe I'll set up another poll. Do you want me to work on the camera (personally I do as it's the only thing keeping me from using it as my dayly) or do you want me to work on the other parts?
OK, I've played with Action Snap tonite and I gotta say that it's nice to have a working camera on CM9. One of the first things that I noticed was the orientation was correct and it would actually capture a dag on picture. It won't work if the camera is set to the slow capture. I think it's the focus.
I glanced at the code for the CM9 camera, then tried to use the CM7 camera. I think I'll look at the CM9 camera as the CM7 camera didn't even load.
Just as a side note. I'm going to change some of the defaults more for my development perposus (can't spell, leave me alone).
I'd suggest going with what you personally WANT to work on.
I'll admit that if you asked me to tell you what I'd like you to work on, it would be the camera, since that's the only thing stopping me from moving to an ICS ROM.![]()
Yeah it works pretty good on the quick pic setting but no flash which sucks cause you have to be somewhere the lighting is excellent.
Okay Not to be F****ed or anything but playing games on this rom sucks...like big time n i am a big gamer..anyway i will make a list of games that do work n dont...
Temple Run 2 *does not work*
Temple Run *Works but only for like 5 mins n reboots*
Subway Surfers *Works 60% of the time but lags and reboots*
NFL PRO 2013 *Works but too much Lags..Reboots*
Drag Race *Works Well..*
Contract Kill 2 *Works for the first 5 mins n then reboots..Also alot of lag*
istunts 2 *work well*
Battleship destroyer *Only Loads n reboost*
The list can go on my test lol
Now all of these games work well on CM7 but not on CM9... I think that the last 4 updates on this rom has to do something with it. (note all of these games work on CM9 11/12/2012 or later)
This is exciting! I got a Nexus 4 recently so I won't be using my Triumph as a phone for much longer, but I plan on using it as a PMP instead, so I'll probably keep an eye on MTDEV's work.
Good job dsm! (I'm glad you found it sooner rather than later for your own sanity.)
Anyone having trouble with proximity sensor? When I'm on a call and take away from face it seems like it takes awhile for screen to light up... Anyone... Bueller ? Thanks!
Is Bluetooth working for anyone else on this build? I have a fairly nice Plantronics headset that I used with this phone before rooting it, but have been unable to find the device in the Bluetooth connection search since then.
Also, thanks to whoever mentioned that overclocking was breaking Maps - I was starting to think I had lost that functionality completely also, but reverting to standard clock speed fixed it.
I got the same bluetooth.It connects but if idle too long it disconnect and won't reconnect.When I try to turn off bluetooth then turn it back on it freezes.Is Bluetooth working for anyone else on this build? I have a fairly nice Plantronics headset that I used with this phone before rooting it, but have been unable to find the device in the Bluetooth connection search since then.
