Did it work/boot up?!
Text mms calls work anything else you want me to test
when i first booted, camera worked fine. but after reboot when i enter camera it just goes to a blank screenAnything and everything. I found that annoying/confusing sleep policy string for WiFi. I have that fixed.
I think I'm going to work on the CM7 SU for a little while.
EDIT: Wi-Fi might have a connection issue. I have a crappy router so I might not be the best data source.
I found that deep sleep mode never happened on this, even with wifi off. It may just be the that the deep sleep widget didn't recognize it, but the percentage never rose from 0% even with Wifi off. Went back to 2-23.
I can't get it running for some reason. Whenever I boot up the phone I get an error message saying the setup wizard failed.
My DEV phone does go into deep sleep. Although I don't have data on, or cell. It might be an app keeping it awake.
Are you using the gapps listed in the first post? That's the one I'm using.
GPS doesn't seem to work either. It can't get my location. I'll try it again tomorrow.
It's possible it's an app, but I don't get that effect using the 2-23. I wonder if it's cell or data?
Anyone else have this?
I installed it without wiping data/cache from the 2-23 version, so that could have something to do with it? Everything else seems OK.
