sx4dude2013
Android Expert
Damn, I just got Liberty set back up today. I might just have to wait a few days first.
Just to make sure, if on. 596 install use the second file first then the main one or should I just sbf back?
Boot into D2bootstrap, install the prep zip, the install the main file and then boot into the rom. After the rom boots, go into the ROMS bootload NOT D2, and install the prep file again. Then boot again and you should be good to go.
Then of course flash the fc fix and mms fix files. Then do batt stats
