Root | ROM | Synergy-Kingdom | NIGHTLYS | 2.3.3 | SENSE 3.0 |
ocnbrze
DON'T PANIC!!!!!!!!!
  • May 13, 2010
    40,490
    1
    33,626
    Los Angeles
    ok guys so i felt that this is worthy enough to put up for all the AF family to share. so this is obviously not mine nor do i take any credit but check this out:
    ║▌ ║▌││░ | ROM | Synergy-Kingdom | NIGHTLYS | 2.3.3 | SENSE 3.0 |░ █║▌ ║
    Synergy-Kingdom nightly folder
    LATEST MD5 0c43b534e3a293308ac50b9a9f399bd5
    For issues PLEASE report HERE to get fixed
    For the list of commits and changes look HERE
    CLICK FOR LIVE CHAT WITH ME AND OTHER USERS
    CREDITS
    PEOPLE WHO DONATED THANK YOU GUYS AND GALS FOR YOUR GENEROSITY !
    GINORMOUS THANKS TO TechworkZ & Unleashed2K FOR BUILDING MY WEBPAGE/FORUM INFECTEDROM.COM
    Flemmard and DiamondBack for sizing this whole rom !!!!
    TrevE, Damageless, Ziggy471 and all the other devs that were a part of this
    football for all the official RUU Leaks
    XDA-DEVELOPERS FOR BEING AWESOME
    THE GOODS
    Added BusyBox v1.18.4 with color output disabled
    Added green overflow scroll (Thanks Robocik)
    Raised available MMS size Limit to 5mb (Default is still 2mb)
    Added Synergy Updater app, allowing in rom updates (Addons and Themes)
    Added DSP Manager
    Rosie settings with right button remap (Thanks MYN)
    New bootscreen (Thanks wrmxtemp)
    Added Screen Scaling and systl.conf tweaks (Thanks Ziggy471)
    Build Prop tweaks for faster screen transitions and call connect (Thanks CapyChimp)
    Framework and Rosie transition times sped up (Thanks Calk and Aamikam for the Logic)
    Added Dancing droid to incoming call screen (Thanks SEO)
    Added Sense 3.0 Lockscreen from HTC kingdom build
    Fixed Nonshowing icons in lockscreen (Thanks SNQ)
    Added 3.0 threaded text messaging (Thanks SEO)
    Added 3.0 Weather (Thanks SEO and Damo)
    Added HTC hub
    Added mod that propertly displays 3G/1X status in titlebar
    Fixed FC in weather (Thanks Virus)
    Fixed FC in weather Widget when clicking (Thanks Virus)
    Fixed auto brightness issue with new kernel from official ota gingerbread Kernel (Thanks Sprint)
    Added Transparent like rosie just like in the kingdom rom (Thanks Virus and Snq)
    Moved some data/app to system app to take more advantage of our system
    Better looking icons on lockscreen (Thanks Snq)
    Sprint/Verizon Mobile Wifi Hotspot unlocked so it is now free (Thanks Leoisright)
    Added Sense 3.0 MMS
    Added HTC Mirror App support
    Added Sense 3.0 USB Menu
    Decreased Wifi Access point scans to save more battery
    Added Wireless N support to Kernel
    Added Sense 3.0 Task Manager
    Added Sense 3.0 Polaris Office
    Customized Sense homescreen layout
    Added HTC Hub support (Huge thanks to aamikam)
    Fixed Rosie/Sense randomly restarting
    Fixed force close when using effects in HTC Album. (Huge thanks to aamikam)
    Optimized Apks (Huge thanks to aamikam)
    Updated supersonic build properties from official supersonic OTA build.prop
    Added H264 native support
    Fixed issue where Android Market wasn't showing all apps/games
    Added Synergy bootanimation (Thanks to the King of bootanimations.. Wrx4memp)
    Updated HTC_IME.apk with non arrows version
    Updated Flash Player to 10.3.185.23
    Fixed Rosie to now have Kingdom transparent launcher while landscape and sped it up (0 level compression)
    Reverted to previous revision of MMS
    Reverted to previous revision of Mail which fixed Mail FC using POP3
    Increased GPS Lock Performance (Thanks Ziggy471)
    NIGHTLY CHANGLOG:
    7/04/2011
    Added Resized Weather.apk (Thanks Unity Team)
    Added Resized Browser.apk (Thanks Unity Team)
    Added Resized Calculator.apk and widget (Thanks Unity Team)
    Fixed Rosie Crashing and raised its priority (Thanks TrevE)
    Fixed Roam settings in options (Thanks Virus)
    Updated and themed latest Launcher PRO
    Removed Sense and will now be installed automatically in 7/5/2011 Nightly so stay tuned
    Added Rmk's user app scripts the rom will now auto install your apks when you flash just make a folder on your sd named SynergyROM and put a folder in there named app.user and all the apks you want the rom to install upon flash just drag in there and it will install ten at a time everytime you reboot (Team effort on that thanks ziggy, TrevE and Virus)
    New Kernel/network/sqlite3 tweaks (Thanks TrevE)
    Added Black themed Swype
    Updated to WiFi Tether 3.1-b1 and change apk to packagename (Thanks TrevE)
    Edited Renice scripts, firstboot, kernel tweak (Thanks TrevE)
    Perflock is now disabled !!! (Thanks TrevE)
    Rom is now themed blue!!
    Added Quick settings to the pull down bar (Thanks Ziggy471
    LOTS MORE GUYS WILL UPDATE IN A FEW
    will add this to the roms/kernel sticky
    well so far i like this rom a lot. super fast and it reminds me of the cm7 i never had. i mean it feels like aosp but it is a sense rom. i do miss the carousel that sense 3.0 has. but i think that it is a very nice rom so far. the loading of the lockscreen is amazing with the weather animation. i mightbe on this one for awhile or at least until virus's kingdom 1.4 comes out.
    Upvote 0
    I've been digging this for a few days now and really like it as well. Agree that Launcher Pro gives it an AOSP feel but you can get to that 3.0 carousel if you want. I did it since that's the only way to change the lockscreen shortcuts but then froze it to get back to LP.
    This is from Neudof at InfectedRom:
    To get sense to auto install:
    1- Before you flash create a folder "synergyROM" (no quotes) on the root of your SD card. (Mine already existed)
    2- Inside that folder create a folder "rosie" (no quotes).
    3- wipe everything/vrsuperwipe.
    4- flash rom.
    What I LOVED about LP is that I backed it up via Preferences before reflashing and that saved a lot of re-setup.
    I also spent a day on Virus's Synergy-Evo which has Sense 2.1 but it goes LANDSCAPE which I've been waiting for since Day 1.
    • Like
    Reactions: ocnbrze
    Upvote 0
    4- flash rom.
    thanx gonna have to give that a try.
    Upvote 0
    Sorry, kind of new to this. But, there's no download link on the site you linked to... and none in your post... wtf?
    on the link i provided, takes you to the xda page. click on the nightly folder and it should take you to the page where the most current nightly is available. download it and you are good to go.
    Upvote 0
    I actually just downloaded From the site, RC1... Hopefully it's the right one, it's a little over half way installed now.
    Stuck on a flashing and moving green Synergy Rom screen...
    Upvote 0
    that sounds like that is just the synergy rom by myn's. this is a nightly rom. in other words virus'has been releasing a new version everyday or few days. they are just tweaks. this is more like an alpha or beta release before and actual release comes out. so somethings may or may not work.
    here is the link for the 7/11 nightly if you want it:http://android-kernels-roms.info/Xx...htly/Synergy_Kingdom_signed_071111_001900.zip
    Upvote 0
    This rom is great. I will have to partition my sd card and re-flash it.
    One question. I liked Azrael because the dev removed all the bloatware. I don't use peep our twitter or some of the other preloaded stuff. Can I just erase it? I would just freeze it with titanium but I want the extra space.
    those should be safe to delete. but if you are going to do that i would make a nandroid first before deleting anything.
    Thinking of flashing this coming from CM7 to this. I do have a question how can I update my radios with? Radio/WiMAX/ and the rest?
    Also, anyone had any troubles outa this ROM what do you guys think of it. Really good? Looks amazing.
    Thanks!
    i just flashed the 7/12 nightly and so far so good. it is a pretty big rom so you may have to partition it. also since you are coming from an aosp rom, make sure to wipe at least a few times before flashing it. i would even recommend that you use vr superwipe in addition to wiping.
    Upvote 0
    Not sure what you mean by partition it. Have never done that before.....Also what about the Radios and the WiMAX stuff?
    Thanks!
    Upvote 0
    Thanks!
    ok so as far as the radios go, it is not necessary to upgrade them. some people have reported that upgrading them helped out with signal strength a little and some have reported better battery life as well. i have not seen any advantages with the newer radios. so that is up to you. same goes with your wimax. if you do decide to upgrade then please read this:http://androidforums.com/evo-4g-all...before-you-flash-your-radios-read-thread.html. i'm not sure if it is still needed but it was recommended that on his kingdom rom to downgrade your pri to 1.77. i have done this and have had no issues so far with it.
    as far as partitioning your card here is the guide i used:[GUIDE][07/07/11]How to Partition your SD Card - xda-developers. the only thing different that i used was to set my swap at 32 and not 0 like the guide mentions.
    Upvote 0
    Anyone else having issues with the 7/12 nightly? I'm up and running and just tried to download a few apps from the market and get an error "There is insufficient space on the device."
    When I look in TiB, I see System ROM has just 7.03MB free, Internal has 211MB free, SD card has 5.5GB free and SD card (a2sd) has 2.90GB (I know, went a little overboard on my Partition)
    The nightly is actually under 300MB (rare for Kingdom, eh) so what's chewing up my system ROM and is that what's preventing me from installing new apps?
    Upvote 0
    BEST TECH IN 2023
    Smartphones
